244 head and 300 husker
HA in Oh
09-16-2004 06:51:51
Purchased a 300 husker last fall and picked 31 acers with it, did a very poor job of husking. I think the problem is in the 244 head, alot of the ears were pulled off at the joint below the ear instead of being snaped off at the cob. This left to much husk and part of the stock and the husking rolls wouldn't pull it off. Could the snaping rolls be wore out or out of ajustment? Are the rolls ajustable? The head has had much more use then the picker, when the picker was new a combine was traded in and the 244 head was kept and put on the picker. The husking bed is in very good shape. I have 65 acers to pick and its got to do a better job this year. HELP!
Roger H
09-18-2004 20:45:59
 Re: 244 head and 300 husker in reply to HA in Oh, 09-16-2004 06:51:51
My neighbor has the same setup you have & he has always grumbled about it not husking near as well even when the JD picker was new compared to a New Idea picker that he used to have. He said the New Idea done excellent on husking but the reason he went to the Deere was the 244 head has stripper plates & the New Idea doesn't which caused butt shelling losses. I have a 643 head on a 7720 combine & I was told that if you could see the ground through the snapping rolls next to the 2 bolts that clamp the rolls to the shaft, they are wore out & I have seen some that were that bad. The rolls are not adjustable but they do need to be timed, to check that, look at the front end of the rolls, you should find a roll pin that helps hold the rolls to the shaft, for each row one pin should be vertical & the other horizontal, if they are not the shafts coming out of the gearbox are not installed right. I haven't looked close at John's picker head to see if his rolls are worn or not but the way he cussed his, I would say it's the husking bed & not so much the head's fault. I'm not sure if you could speed up the head by changing sprockets around like I have done on the combine or not. I hope this helps some.....Roger
