3 pt lifting weight for 52 B
mrs
09-15-2004 18:20:27
I have tried to move some small round bales with my B and am having trouble lifting them. The previous owner moved small bales pretty easy, I know the weight of the bales could be a little off but I don"t believe it is that much. The fluid is dripping out of the petcock, is that enought fluid or could I be low. What is the proper fill level. Thanks for the help
cranepilot9
09-16-2004 09:30:06
 Re: 3 pt lifting weight for 52 B in reply to mrs, 09-15-2004 18:20:27
You probably know that the 3points on lettered tractors are add-ons. They really are not made to lift and carry like the true 3-points. Ive had one on a G but finally took it off. It bent one of my rock shafts. Most likely the seals in the rockshaft hyd cylinder are giving up. Does it bleed down under a load?
