720 Pony Motor
Beanie
09-15-2004 16:26:01
I have been having trouble with #1&3 cylinders not firing. So I put all new spark plugs, plug wires, points, condensers and coils and I still have trouble with #1&3 not firing. Now here's my question? The little bar that the coils slides on I took notice when I have it running on the #2&4 cylinders it fires good, but on the magnetic bar when I put a screw driver on the end that fires the #2&4 cylinders it has a pretty good magnetic force pull. Now on the other end of that magnetic bar that fires #1&3 cylinders I laid a screw driver on that end and there is no magnetic force pull. Is this normal or what is the real problem here?
Clooney
09-16-2004 06:34:24
 Re: 720 Pony Motor in reply to Beanie, 09-15-2004 16:26:01
Beanie, I haven't ever checked a pony coil that way but you said you had a good spark on those 2 front cylinders in a previous post.. If you have a good spark to the plugs then that particular coil is working..
Will your coil push a bluish colored spark across sparkplug(s) that that have had the electrode gap opened to 3/16� ?.. IF SO, your coil, points, condenser, & entire ignition side is working properly..
On that coil only magnetizing one end of the core?.. That�s entirely possible if on one end that coil is energized with the points being closed & on the other that coil is reversed polarity.. With only one coil powered you would have magnetism with both energized you could have opposing magnetic force & no apparent magnetic field..
I haven�t found that coil polarity is a big factor on the pony ignitions as no matter how you wire it, one plug on each bank will spark at reverse polarity.. If you reverse the coil wiring it just changes which plug is reversed.. [no big deal either way]
[email protected]
