Advice on a 2640
Dwight
09-15-2004 15:23:00
I am rather unfamiliar with 2640 but am considering buying one with about 2500 hours on it. It is a 1976 with a hi/lo. Appears to be well taken care of. Is is a good rig and are there things I should watch for? I currently have a 2755 and had been looking for a 2355 but this came up and has alittle more hp and is the same profile. The local dealer never sold a 2640 so I have no local experience to draw from. Thanks for your help.
Allan/CA
09-17-2004 08:00:26
 Re: Advice on a 2640 in reply to Dwight, 09-15-2004 15:23:00
The 2640 is a good tractor but the hi/low can be costly to repair. I purchased mine with a weak hi/low because the dealer wanted 8000.00 to rebuild it, and I got it cheap. They wanted 2800.00 just for replacement unit and a after market company wanted 1800.00 for the parts but the dealer wouldn't back it up if it failed. Another shop did a good business just gutting out the units and running a shaft thru the empty housing making a standard shift. I found another transmission and I'm going to install it and block out the low shift side. You may never any problem with the one your looking at. It just seams to be more of a problem with the 70hp of the 2640 and not the lower hp tractors or the newer models. I have a 2355 with the hi/low 4wd and its great. Good luck on what ever you do. Allan/CA
Jess
05-25-2005 17:27:30
 2640 hi-low in reply to Allan/CA, 09-17-2004 08:00:26
I am looking for a rebuildable hi-low, or any misc hi low parts for a 2640 John Deere.
msb
09-15-2004 19:30:20
Its a very good model although I prefer the 2630 simply because of the styling of the 30 series.
