Help w/B Governor...Clooney or others
PeteNY
09-15-2004 09:24:33
Clooney, TY for the reply to Dad's(Dave2N) post on the late B governor. We have removed the vertical shaft...the problem appears that the spring on the mag. side seems to be contacting something (possibly the fan shaft gear?) thus preventong the manin shaft from coming out whole. I can get about 1/2" movement then it stops...when pushed from the mag side, it will move more, but it is obviously only the spring collapsing, as it returns when pressure is removed. So my question; if the spring is infact hitting the fan shaft gear...can I get enough forward movement in that gear simply by loosening the flange? or do I need to completely remove the governor case. Man, this was sooo easy on the 70! Thanks, Pete
Mike M
09-15-2004 09:43:20
 Re: Help w/B Governor...Clooney or others in reply to PeteNY, 09-15-2004 09:24:33
I would guess that the bearing race is stuck in there,maybe rust or someone before used loctite ? It should take more than 1/2" to hit the fan ? Have someone hold it to the left against the spring tension then give it a wack with a block of wood and a hammer and see if it loosens up.
Dave 2N
09-15-2004 18:41:35
 Re: Help w/B Governor...Clooney or others in reply to Mike M, 09-15-2004 09:43:20
Mike-
Some PB Blaster, piece of a hardwood sledge handle and a few hits got it out.
Thanks for your help.
Mike M
09-16-2004 05:57:55
 Re: Help w/B Governor...Clooney or others in reply to Dave 2N, 09-15-2004 18:41:35
You did good to proceed with extreme caution as not to damage more than needed. But sometimes you need to use some extra force.
