Check out my B
Nate JD
09-15-2004 08:09:54
Just wanted to show off my '42 B I just finished. I recieved lots of help just by reading this board and special thanks to Clooney for answering some questions and FIT for his cool lye gravy and electrolysis techniques. What do you think?
Nate
http://www.johnnypopper.com/forums/index.php?s=5e15494e3ab61e126c876d72503f9863&act=ST&f=3&t=3979&st=0#entry18782
Jon C -Florida
09-15-2004 15:44:15
 Re: Check out my B in reply to Nate JD, 09-15-2004 08:09:54
Nate - you did a fantastic job! Well done!
Will P
09-15-2004 14:51:12
third party image
Here is one of the pictures of your B posted.
One thing I noticed about your B. It has a cast iron frame. Which came out at serial number 136662 to 166999. The 42's last serial number is before that. Can't find my books right now for that number. If your serial number is after 136662, it is a 1943, not 42.
I have 141524 and she is certified as a 43 by mother Deere.
Will P
43A
43B
49G and soon 47G
Nate JD
09-16-2004 19:33:01
 Re: Check out my B in reply to Will P, 09-15-2004 14:51:12
Will, because my tractor has the steel serial # plate, it is in too poor condition to read it. My research (mostly from 2 Cylinder) shows 1943 models starting at 143,420. Maybe it has something to do with the production year versus the model year thing. Your tractor looks great too. Thanks.
Nate
Will P
09-16-2004 20:55:50
 Re: Check out my B in reply to Nate JD, 09-16-2004 19:33:01
143,420 is the first tractor made IN 1943. Deere started the model year in July of the previous year. According to most sources, mine is a 42. But Deere has told me it is a 43. Along with my 43A that most books state it is a 42. 521175
I specialize in war tractors. Cast frame, with no pressure cap radiator. 100%, 1943!!! No ifs, ands or buts!!
She looks NICE!!!!!
Will P
Nate JD
09-17-2004 04:34:55
 Re: Check out my B in reply to Will P, 09-16-2004 20:55:50
Will, thanks for the insight. Since you specialize in war tractors I thought I'd ask you some questions about the tractor. If you go to the link above and see all the pictures, look at the spoke wheels. They were cut-offs (10 spoke)and the hub was broken on one so I couldn't use them. Do you think the tractor was shipped on steel with a 4 speed because of the war and upgraded later or were these wheels just put on later for some other reason. I wish I could have used those old connected bar tires and spokes. The fan shaft also has a belt pulley on it. Was that just a standard replacement part from a later date? Thanks.
Nate
Will P
09-17-2004 21:57:48
 Re: Check out my B in reply to Nate JD, 09-17-2004 04:34:55
The rear was steel. And that would make it a 4 speed tractor. Removable hubs came out later. And your cut-offs didn't have removable hubs, which probably means they were original. Those were nice "original" tires on that tractor. Those are pre-war tires.
Do you have the cut-off steel rears? Look inside the hub for a part number. Regular rear steel and tip-toes have different numbers. My 43A was all steel with tip-toes and a two row mounted corn picker. My 43B was steel front, cast center, rubber on the rear.
Fan shaft belt pulley. The fan shaft that you "had" on the tractor was a rubber mounted fan. When the rubber fails, the fan will kiss the radiator. Most have been replaced with the "improvement" kit. Which will give you a spring loaded hub and a pulley for a generator. It is a "service" replacement. My fan is still rubber mounted. Have to keep an eye on it.
Have you taken sand paper to the tag? That is what I did to my B and A. Can't hurt the tag, if you can't read it.
Will P
Will P
09-15-2004 14:54:24
third party image
Mine.
farmallman
09-15-2004 09:47:39
AWESOME. I love it...maybe am a bit jealous :) O well, maybe my G will look like that some day.
