3020 gas line size
Robby
09-15-2004 07:21:36
I am wanting to put an inline fuel filter in my 3020 gas. I want to put it in between the primer pump and gas tank. What I need to know is what size is the gas line ( diameter) of the old metal line. I am at work and my tractor is out at a friends, he is using it to hay and had some trouble last night. thanks in advance
Gerald J.
09-15-2004 09:00:16
 Re: 3020 gas line size in reply to Robby, 09-15-2004 07:21:36
1/4" OD on my 4020 gas. Put the filter between the pump and the carburetor. That's where the JD kit puts it. Then it can be easy to get at. The previous owner on my 4020 put it between the tank and the pump and after decades the hose pieces rotted and it leaked all the time and was a pain to get at while it dripped on me.
My 4020 got so it would only run with more than a quarter tank of gas. The pump was bad. I mounted an electric pump in its place, now it gets down to the last couple inches in the tank. Its nice that the electric pump can fill the carburetor without having to waste battery power cranking the engine (and building up hydraulic pressure).
Gerald J.
Robby
09-15-2004 09:58:56
 Re: 3020 gas line size in reply to Gerald J., 09-15-2004 09:00:16
Thank you!!!!! !!!!
