400 rockshaft position
drdrew
09-15-2004 07:03:12
I have a John Deere 400 purchased recently and am restoring as faithfully as possible. One issue I have is I replaced the lift links for the mower deck (as they were welded in place) and am still having lift issues. The 3-point hitch lifts fine and the lift cylinder is not leaking. I noticed the rockshaft (that connects to the "rockarm", I think its called) appears to have been broken and re-welded. It appears that the holes, when rewelded, are about 3/8" off which I assume would compensate for my lift problem. Can anyone tell me if the holes should be straight up and down, angled, or whatever to the sides of the rockshaft. The nearest dealer is about 30 miles away and the phone is always busy. I will replace it, as it needs to be anyway, but am wondering if I need to look any further into my problem or if this is it. Also, with the cylinder all the way closed (deck is down) what the alignment of the holes should be also? Not sure if maybe the shaft itself has turned or not, probably not, but still wondering.
Thanks,
Andrew
