2520 Coolant Question
LAZY DAYS
09-15-2004 05:28:18
When I work my 2520 gas, for instance pulling a disk on a hot day obviosly the radiator coolant gets hot.
My problem is that the radiator will start to over flow out of the fill cap.
Nothing outrageous, but a small stream.
My question is this, do I need a new radiator cap ?
Should the system be air tight ?
Do I have too much coolant in the system ?
I have it filled to the top of the core now.
( about 2 - 3 in. from the top of the radiator )
What should I do ?
As I said earlier it will only overflow when it is real hot.
The coolant is a 50/50 mix less than 6 months old.
And the radiator was boiled ( cleaned ) about 6 months ago and a new thermostat was added.
The engine is not overheating.
Fred G
09-15-2004 10:31:24
 Re: 2520 Coolant Question in reply to LAZY DAYS, 09-15-2004 05:28:18
I grew up with a 2520. Ours would always run at the 3/4 point on the temp gauge on hot days. Doing primary tillage it would get a bit hotter, but never overheat. If your temp is in the normal band (not in red), it sounds like the spring in the radator cap is fatigued and it's releasing at too low a temperature. Replace the cap with a new one and your problem should be solved.
