Front Axle Grease for H
JD Don
09-15-2004 03:49:55
My JD H front hubs (cast) have zirc fittings tapped into the center of them. This makes me think I should use a moly/lithium based grease gun to pack the bearings, instead of standard wheel bearing grease. Is the zirc fitting on the hub standard (it doesn"t appear in the parts manual) and which grease do you recommend?
dan_41jdh
09-15-2004 08:23:44
 Re: Front Axle Grease for H in reply to JD Don, 09-15-2004 03:49:55
JD Don, Deere never furnished any grease fittings for the "H" front wheel hubs. (You"re probably referring to the cast hub caps for the cast wheels used before stamped steel wheels came into production.) You occasionally see those H hub caps with zerk fittings tapped into them, but it wasn"t from the factory like that. Apparently, owners didn"t like the thought of actually having to clean and repack wheel bearings, so they would install a grease fitting and would just pump away with their grease guns.
You may use almost any grease intended for wheel bearing applications, and it will work fine for the H.
jd don
09-15-2004 12:39:14
 Re: Front Axle Grease for H in reply to dan_41jdh, 09-15-2004 08:23:44
Thanks...that"s pretty much what I figured. By the way, my "44 H has the cast hub caps (covering the wheel bearings) but with steel stamped wheels. Even though I have the "after-market" zirc fittings, I think I"ll use regular wheel bearing grease.
