JD 112 Variator revisited
JTWalk
09-14-2004 18:34:46
Had trouble with tractor accelerating with the variator in the forward position.If I pulled BACK on the clutch/brake pedal the variator would drop back and the tractor sped up,but the C/B pedal is way higher than the 7 to 8 inch maximum distance allowed to the footrest. Then when the pedal is pressed to slow down, the variator drops back down into slow speed. Checked into adjusting the clutch override, and noticed the eyehook that threads into the clutch override spring/shaft deal was bent. I replaced eyehook and secondary drive belt. Tractor accelerates and slows down w/ foot pedal, but pedal still raises very high in the fastest variator setting.Almost straight up and down. Also have some excessive vibration (i.e. steering wheel} that seems to decrease when I hold pedal down at 7 to 8 inch dist. off the footrest. This is giving me some problems and any input would be appreciated
Wayne in Tn.
09-15-2004 14:36:59
 Re: JD 112 Variator revisited in reply to JTWalk, 09-14-2004 18:34:46
The first thing, on those old 110 and 112 models, is make sure you use John Deere belts. Other brands may be slightly different and will not operate correctly. The owner-operator manual goes into detail as to adjusting the variable speed. Also oil the variator up good to where the pulley halves can move freely. Also there can be a groove worn on the variator shaft, causing the pulley to hang up. I believe I have a copy of the manual somewhere, will have to look it up.
