GP sparkplugs
J bouchard
09-14-2004 12:23:13
Since I can no longer find AC plugs for my tractors, I wonder what is a good general use sparkplug for parade use ,show use from Champion or Autolite. In fact, recomendations for all early John Deeres would be appreciated.
ET
09-15-2004 07:15:26
 Re: GP sparkplugs in reply to J bouchard, 09-14-2004 12:23:13
I use autolite 3077 in my GP. They are a little hotter than the 3076 and the electrode sticks out farther into the combustion chamber.
Duane Larson
09-14-2004 21:34:32
J bouchard,
What year is your GP? The small bore GP's used a pipe thread plug from the factory, initially a Champion 7, and Champion renamed the 7 to 31 in 1929. The Champion 33 became available in late 1929 (hotter than the 31) and was used until the big bore came along in Dec 1930. At that time the decision records called for an AC L12 plug, and in March 1932 Champion 3X and C4 were added. These were used to end of production.
The 3X is still being reproduced for Model A Fords, and are available. I prefer the Champion 2ComL plug (usually listed as a replacement for the GP until 1961 when it was replaced by the W18) - both are 2 piece take apart plugs, but the 2ComL has a glazed porcelain tip which makes for easier cleaning. I have been running a set for 10 years in a GP, and the ability to take them apart and clean the fuel/oil fouling from the glazed end is the reason they last so long. They are also available NOS from old plug dealers like Don McKinsey.
Similar info is available for the early A, B, G, and D - if you are interested.
TRoth
09-28-2004 18:31:22
 Re: GP sparkplugs in reply to Duane Larson, 09-14-2004 21:34:32
I was fascinated by the information you gave for the GP. I have a 39 B JD that is ready for new plugs. It currently has a dual electrode plug in one side and a single elecrode on the other. Can a person still get dual electrode plugs? What would actually be best? Do you have a suggestion for plugs for a 1950 A with alluminumn pistons? Thanks so much, TRoth
toot
09-14-2004 12:28:06
Autolite 3076
