Got my 40 Running but ...
Cal B
09-14-2004 11:53:31
it smokes. I rebuilt the carb, changed oil, plugs, points, condenser, built new wires. After sitting idle for 5 years, it started right up, but it smokes pretty badly. Does this mean that it needs a ring and valve job? If so, what is a ballpark cost figure for getting that done?
Thanks!
Cal B.
Nacogdoches, TX
DiggerLarry
09-15-2004 10:16:19
 Re: Got my 40 Running but ... in reply to Cal B, 09-14-2004 11:53:31
Cal,
I'd get a compression guage and check the compression. It may need rings. The only sure way to know it to pull the head off and look. They aren't too bad to rebuild unless you have to bore them which is likely on the 40's as they have been around several years.
