JD 50 Rockshaft
BillS
09-14-2004 10:23:47
My rockshaft on my 50 won't work. I just took the loader off and the loader worked fine. I put the plugs in like it said in the owners manual, but now, nothing. There is kind of a groaning noise and the tractor does idle down like its trying to do something but the shaft doesn't even twitch. Any simple ideas? Thanks!
F-I-T
09-14-2004 11:35:36
 Re: JD 50 Rockshaft in reply to BillS, 09-14-2004 10:23:47
Bill:
It could be that the rockshaft is up all the way. Can you bring it down using a large Crescent or pipe wrench while pulling back on the Powr-Trol lever? Once down it should raise itself if all else is well.
Frank
Clooney
09-14-2004 10:49:36
third party image
BillS, you say..
Quote: "I put the plugs in like it said in the owners manual, but now, nothing. There is kind of a groaning noise and the tractor does idle down like its trying to do something but the shaft doesn't even twitch. Any simple ideas?"
--Are those "PLUGS" open front plugs? If not & you instead used adapter plugs from the loader hoses, that rock shaft will never work but will load the pump & make a noise when activated.. The fluid MUST be able to flow out the front [see picture]..
[email protected]
BillS
09-14-2004 11:13:51
 Re: JD 50 Rockshaft in reply to Clooney, 09-14-2004 10:49:36
Your picture didn't come up for me, probably my old slow antiqudated computer. The plugs were in the little rack on the side and have metal covers that you unscrew. They are kind of long and have a hole in the end and then another hole crossways too. Are they the right ones?
Clooney
09-15-2004 03:11:41
 Re: JD 50 Rockshaft in reply to BillS, 09-14-2004 11:13:51
BillS, the picture didn�t show for me either [it's on a server I don't use much any more].. To view the picture just right click on the red X, then left click on properties, then copy the URL under properties & paste that into your address box at the top of most web pages.. Then move your cursor over to the right & left click on GO.. That should allow the picture to open.
It sure sounds like you have the correct plugs [need to have open front ends]..
Frank brought up a good suggestion in his post above mine so look there.. You might also do a throttle valve & metering valve adjustment on your Powr-Trol box [those two capped nuts [one on the rear & one on the L/H side].. It�s possible someone backed the throttle valve [one on the rear] adjuster all the way out so the rockshaft would go all the way & stay there.. Try turning the throttle valve adjuster screw in a few turns & see if that helps.
[email protected]
