110 JD wont crank
Chuck McDonald
09-14-2004 05:34:27
Hi,
I have a 1971 110 rider with the 8 hp kohler motor. It has been working fin up till now, however when I went to start it a few weeks ago, nothing would happen when i turned the key. I have checked the battery and replaced one battery cable that looked bad. Also, I have giggled all the cables when trying to start it but nothing happens. When you jumper from the batt to the starter on that little round black box on the side of the hood where all the cables tie in to, it willl crank perfecly. Is that box bad(what is it called) or could it be my key switch? Does anyone make new wiring harnesses for these tractors?
Please help, I really dont want to push mow this week!
Thanks
Chuck
STILL NO GO
09-14-2004 12:52:42
 Re: 110 JD wont crank in reply to Chuck McDonald, 09-14-2004 05:34:27
Hey,
I replaced the solenoid and the key switch and still nothing happens. Also, The wires that run back under the floor to the transmission have been jumpered with a short picece of wire, so that should not be the problem.
What is the small metal box that the small wire runs from the battery to this box then another small wire run on to the key switch (or ammeter i cant remember) area? COuld that be keeping me from getting current to the solenoid?
Where can you get wiring harnesses also?
John T: Could i get your phone # so i could call you if i have more ?'s. Email it to me.
Thanks
Chuck
John T
09-14-2004 13:16:53
 Re: 110 JD wont crank in reply to STILL NO GO, 09-14-2004 12:52:42
Chuck, then it sounds like your neutral safety switch has been by passed?? As Dave (WTW) so well described to ya below, there's that Normally Open Neutral safety switch PLUS maybe?? another one (UNLESS its also been by passed) so the mower drive must not be engaged before the hot voltage from the switch (when in crank) will reach the lil solenoid activation terminal.
A test light must glow out the switch when in start,,,,, ,then to n thru any Normally Open Neutral Safety Switch (unless by passed) ,,,,, ,then maybe (if so equipped n not by passed) to n thru any mower deck engage safety switch,,,,, ,,then to the solenoids lil activation terminal,,,,, ,,,, then to n thru the solenoids coil,,,,, ,,,,to frame ground.
Again, the lil solenoid activation terminal MUST GET HOT (via the switch n any safety switches) when in the start mode or else its a bad switch or a missing wire or circuit from the switch (via any safetys) to the solenoid. If the solenolid is well grounded and a hot voltage on its lil activation terminal dont make it close, then its a bad solenoid. Jump direct a hot wire to the solenoids lil activation terminal and if that makes her start the solenoid is good so its a bad switch or a bad safety switch or an open or missing wire from the switch, via any safetys, to the solenoids lil activation terminal.
Call me if u like Im in Bloomington, Indiana
(812) 824-4608
John T
andy b.
09-14-2004 19:55:26
 Re: 110 JD wont crank in reply to John T, 09-14-2004 13:16:53
Chuck, John,
it does sound like the tranny neutral switch has been bypassed. as John stated, could the small box with the wire from the battery be the PTO safety? on my '66 110 that switch is mounted on the tractor frame on the right side just behind the drive pulley on the engine. also, i believe there is a fuse behind the dash for the ignition circuit.
there isn't much to the wiring on these old girls. just the battery, ignition switch, tranny neutral switch, PTO safety switch, fuse and solenoid (maybe the voltage regulator is tossed in there somewhere). the first time mine wouldn't start i just started at the battery and followed the circuit to the solenoid with a voltage meter, checking for continuity at each piece. the circuit ended up being broken at the tranny neutral switch, but it should be a simple matter to find whichever component isn't working.
andy b.
jhill
09-14-2004 12:34:34
You have to push down on the shifter in neutral on both my 110 and 112 before they will start. They have been that way for years.
andy b.
09-14-2004 09:22:22
Chuck,
i see some of the replies mentioned the solenoid and other parts of a "normal" ignition circuit. i'm with DW though. EVERY time my '66 110 wouldn't start it was because of that dang transmission neutral switch. i finally just bypassed it. i would check that before going any further. on my 110 the switch is located on the underside of the front of the tranny. i am not sure where it would be on your year of tractor.
andy b.
John T
09-14-2004 10:17:30
 Re: 110 JD wont crank in reply to andy b., 09-14-2004 09:22:22
Good point Andy, on my 110 there is a fairly strong spring that holds the shifter in NEUTRAL (once placed there) and I bet if that spring is weak/broke and/or the neutral safety switch is touchy/weak or misadjusted, thats yet one more potential problem if the problems NOT the solenoid (which hot jumping to its lil activation terminal as I described for him will tell) or his key switch.
Dont ya love all them safety switches lol
John T
WTW
09-14-2004 08:41:18
Chuck, Power (12 volt) from your key switch goes to and through your transmission neutral start switch then through your PTO switch and then on to your starter relay / solenoid. Get yourself a 12 volt test light and follow the starting circuit through it's path checking for power when the key switch is turned to the crank / start position. Your problem is in this circuit and most likely in one of the safety switches. Wiggle the transmission lever around as they are very common to fail. Good Luck, DW
John T
09-14-2004 06:58:07
Chuck, if that "black thingy" has big cables to the battery and starter and a small wire up to the key switch, its the starter solenoid. What it does, via its internal relay, is connect the big input cable/terminal from the battery to the output terminal/cable to the starter when its activated by applying voltage to its lil activation post thats wired up to the key switch (small wire). When the switch is in the start position, it has a start terminal that is energized which is supposed to activate the solenoid so the battery gets to the starter.
The problem could be EITHER:
a) The key switch isnt sending hot voltage down to the solenolids lil activation terminal when its in the start position, or,
b) The wires missing/open/broke from the key switches output down to the solenoids lil activation terminal, or,
c) The solenoid is bad, or,
d) The solenoid may not be grounded (rusty or corroded mount or missing ground wire to frame)
TROUBLESHOOTING
1. If you jump connect a hot wire (like off the battery +) to the solenoids lil activation terminal the solenoid pulls in and she cranks, the solenoid and ground is good but theres a problem in the key switch OR the wire from it down to the solenoid. A test lamp on the key switches terminal that leads down to the solenoid should glow when its in the start position and likewise (IF the wires good) the solenoids activation post.
2) If the jump test above dont make her crank yet a test lamp glows on the solenoids lil activation terminal when shes in the start position (or jumped hot), the solenoid is the problem or the solenoids not grounded (via mount to frame or a ground wire to frame).
From your post I wasnt sure if by jumping you meant you jumped around the solenoid (effectively tied big cables together) with a big cable and she cranked, or if you just jump/hot wired voltage to the lil activation terminal on the solenoid she cranked (solenoid is good).
You might wanna remove n clean n wire brush the solenoids mount bolts or any external ground wire from it to the frame in case its only a bad ground problem.
The switch has to send voltage down to the solenoids lil activation terminal, a ground return path is needed for the solenoids coil, and the solenoids relay has to close (connect battery side to starter side) to work
Let us know, Good Luck n God Bless
John T
MarkM.
09-14-2004 05:43:56
It's called a solenoid and needs to be replaced. When you activate the key start, it connects the starter motor to the battery. Replace it and you should be O.K.
