Electric Clutch on Deere 317 question? Clooney or
Tim in PA
09-14-2004 03:49:52
Guys,
I repowered my 317 w/ a new engine. Now I'm having problems with the clutch. The clutch will engage for about 5 minutes or so when cold. Then it will kill the engine. After that, I cycle the pto switch, wait and the clutch will click and then the engine will start. The amp gauge doesn't work, but putting a voltmeter on the battery, shows a drop to 6 volts when the clutch engages and kills the engine. Is the clutch shot? Will a dead short act like this?
Tim in PA
09-15-2004 06:04:28
 Re: Electric Clutch on Deere 317 question? Cloone in reply to Tim in PA, 09-14-2004 03:49:52
It was the clutch. I pulled the clutch off and it had a spot where the field coil, windings were exposed. Swapped in a new one and it seems to work fine.
Thanks
Henry J
09-14-2004 20:27:12
Tim
How is it killing the engine. Is the engine being stalled out like too much load. Or is the engine dying like someone turned off the key?
Jericho
09-14-2004 11:48:46
Tim,
Ma had a very similar problem on her 317. The dealer put a new pto clutch in it, and it still didn"t help. He said that it must be a short or something in the wiring harness, and it would be real expensive to pay bench fees to have them track it(because it is a re-power, not original). She ended up buying a different mower. The 317 is still at her house, waiting for me or my brother to get time to go look at it. If you come up with anything, let me know. I may have the same problem.
JP
