Duals on a 720 D standard
Markus
09-13-2004 18:43:57
ANybody ever put duals on a 720 or 70 standard? How would be the best way to do that?
I sink in too much with only 1 set of tires.
randy hall
09-14-2004 18:58:06
 Re: Duals on a 720 D standard in reply to Markus, 09-13-2004 18:43:57
18.4x30 are the same height as 13.6x38. a neighbor ran this setup on a 70 standard for many years.
Mike Aylward
09-14-2004 12:14:27
Markus, I am assuming being that your tractor is a Standard that you have 30" wheels. You will probably be limited to rim mount (band style) duals. You can mount hubs from newer tractors on your axles but I am not aware of any 9-bolt 30" wheels. The band duals will not cost much (or shouldn't) as they will not be in high demand. However, if someone thinks you really want them (as uncommon as they would be) they might try to tell you they are very valuable due to their "scarcity". Odds are you could go to an older Allis-Chalmers dealer and find some there as some of the AC tractors used a 30" wheel. About the only other alternative would be to go to a 34" or 38" wheel where dual wheel combinations are very common and much easier to find. Hope this helps. Mike
TBSCOTT
09-14-2004 09:18:56
I have a set on a 720 and 730. They are 15.5x38 and are the "clamp-on" style. this works fine and were pretty cheap to come by.
