JD 3010 ignition wiring?
sparrow
09-13-2004 14:56:33
our 3010 will not start, it will start if you short it out on the starter..... so we put a new ignition switch in and it still wont start.
The local dealer is puzzled and has no suggestions as to what's wrong. i'd rather not have to take it in..... any ideas?
Gerald J.
09-14-2004 18:18:46
 Re: JD 3010 ignition wiring? in reply to sparrow, 09-13-2004 14:56:33
Be sure the transmission is in park. Then check the linkage and the end play adjustments that actuate the starter interlock switch. Takes the shop manual to do it right. I don't think its covered in the I&T manual only in TM-2039.
Gerald
m sb
09-13-2004 21:43:02
Have you checked the neutral switch? Its located under the cowling on the right side.Jumper across the two connections.Just be sure to NOT get run over doing it!You may have to replace the wiring from there to the starter.
