bent
09-13-2004 09:11:44
I spent all day Saturday trying to get my '37 D home. I was raining all day. The tractor was back about 40 feet in the carraganas. When I got there, I had to unhook trailer and back in as far as i could. I ran over an old pickup with steel teeth, blew a tire. Yard was black mud and my tires got full, would budge it, had to traction on wet grass with tires full of mud. So the seller volunteered to pull it out with his tractor, as long as I would give him a ride to go get it 2 miles away. He got it out, so I asked him if he could pull it on the trailer for me. I jackknifed the trailer and he started pulling. The tractor had one good rear (fluid), one flat, and no fronts, just rims. So up it was coming, I thought this won't be bad, then the truck slid sideways on wet grass, I didn't notice the ramps popped up (was pulling on backwards) By the time I stopped him (he was watching the field in front of him, not me) the steering rod was bent and the other ramp was agin the flywheel. Not good. So we pulled it off, and he had to go. Okay, I told him I could pull it on with my hand-winch. The one that was still sitting in the doorway where I had forgotten it. So I drove home (about 50 miles) and picked up the winch and went back. I wasn't going to leave it out in the open for midnight salvage. I back up and hooked up the winch. Everything went quite smooth until the pulley bushing on the winch gave out, and the hard-won progress up the ramps was lost as the tractor made its way back down, miraculously straight. After some digging around in his shop I found a bolt that would fit, and went at it again. It was now getting dark, so I was working from the cargo light on the truck. I got it loaded and chained it down. I was soaked through and through, tired, hungry, a bit crusty, but I was on my way to supper and dry clothes. Until, about 10 feet from the main road, I lost all traction and spun out with all four mud-plugged tires. I noticed he was in the house again. So off we went, to get the tractor back from the same place as he had just returned from leaving it, about 2 miles away. The 7000 Allis made short work of the pull as well as the plastic cowl under the bumper, but I was on my way, finally. Sure it is not anything really special but I already have a good story to tell about my "soaker" D.
