2 cyl diesel flywheels
CFWelles
09-13-2004 04:37:26
If one of you experienced fellows has the time, I would like you to comment on flywheel related problems with the 2 cyl diesels. As you may have read on my earlier posts, I am in the process of purchasing a 730D. I have read a lot of background on this board on the subject. I perceive the vulnerability to flywheel looseness to be a machined fit between a straight cut splined wheel and a spline on the crank end. Do I understand it right that the engine pulses over time frequently destroy that toleranced fit? Also I understand that the bolt torque of 300 ft=lbs or so just holds the flywheel firmly on the end of the crank. One of you warned about lugging these motors. I take that to be that the firing pulses cause more and more shock as the motor slows thereby causing more damaging effect on the flywheel splined fit. I also have read that a fellow in Tennessee has made a taper lock hub modification to allow the splined flywheel to be cinched onto the crank to correct looseness of the original assembly. Also, I have not seen diagrams yet of the clutch assembly but realize that power likely is transferred somewhere from a sideways oriented crank to a front to back oriented transmission gear set. Do I understand correctly that the crank thrust washers are under constant wear from the clutching action that throws the crank against them every time the clutch is actuated. Is this why the thrust end play often can get out of whack more freqeuntly on this motor than most engines? I would appreciate any comments on my understanding from you experienced fellows that you are willing to share. Thanks. Also, I know that you must actuate the clutch in and out while measuring thrust play and intend to do this on the tractor I have a contract on before final settlement. If anyone wants to comment on the best procedure to measure this, I would be appreciative of that too. Charlie
buckeye al
09-13-2004 14:36:54
 Re: 2 cyl diesel flywheels in reply to CFWelles, 09-13-2004 04:37:26
Have had three episodes with loose flywheels on 70 & 720 tractors. For some reason, all three sounded like something was loose & pounding in the clutch or right side of the tractor instead of the left at the flywheel. This compounds the lack of attention Clooney mentions. On the 720's just torquing the bolts solved the problem. The 70 (my tractor) however had a cracked bolt boss requiring a new flywheel. Back in the mid 80's however the taper locks only cost a foot or so instead of both an arm & leg as today. Yes they are a pain to set the crank clearance on. Yes I've had it walk a bit requiring re-setting three times through the years. I keep close tabs on it though and this tractor does a lot of stout labor. The flywheel was well worth the purchase. I don't regret it a minute.
Later.
ebbsspeed
09-13-2004 12:12:10
Quote "but realize that power likely is transferred somewhere from a sideways oriented crank to a front to back oriented transmission gear set"
These old 2-cylinder tractors do NOT have front-to-back oriented gear sets. Every shaft in the transmission runs side-to-side just like the crankshaft and rear axles. The exception is the PTO, which is driven by a set of 90 degree bevel gears in the very bottom of the transmission.
Mike M
09-13-2004 08:06:38
On the models R,80,820,830 JD used 2 large keys,like they started out with on the old D,these seem to give alot less trouble than the splines.
Clooney
09-13-2004 07:13:08
CFWelles,, ALL, horizontal 2-cylinder Deere tractors can have a flywheel to crankshaft problems if the tractor is used with a loose or not completely tight flywheel.. It�s just the diesels are more prone to the problem..
My personal feeling is the diesels are worse because of the harsh firing pulses & the knocking is a lot harder to initially hear on the diesels so by the time the owner hears the noise it�s too late..
If those flywheel bolts are kept tight & re-checked after a few hours of use after installation they won�t cause any problems.. Personally I haven�t ever had one come loose that was tightened properly & checked after a few hours of hard usage.. I have repaired quite a few that were run loose though & that can get extremely expensive & become a lot of work..
That classic loose flywheel gremlin can be caused by either too loose pinch bolts or too tight pinch bolts that stretch those rather soft production bolts.. 300� lbs is probably too much on a production bolt & once they stretch there is just NO WAY keep them tight again without replacement.
The good news is: IF the crank splines aren�t too torn up those taper-lock flywheels do seem to work good but are a pain to install & set the proper backlash on.. The down side is the initial cost of a taper-lock flywheel.
When (IF) you buy that 730 be sue to check the flywheel for being tight on the crankshaft [if possible before buying] but checking before is difficult to do if the previous owner has made a temporary repair so the tractor can be sold.. It�s so easy to do a quick short term repair that will hold just long enough to sell the tractor & if done with intent to defraud will be hard to see until you have the tractor home & working..
Quote: �Do I understand correctly that the crank thrust washers are under constant wear from the clutching action that throws the crank against them every time the clutch is actuated.�
--On the thrust washer issue? -- That isn�t a big problem unless the clutch handle is ridden [held onto all the time] that keeps constant side pressure on the thrust washers.. Just snapping the clutch in & out is [should be anyhow] so quick that not much wear occurs. Those thrust washers are way more prone to damage if the crankshaft end play is allowed to run while loose, or the thrust washers are allowed to fall out of position when working with the flywheel.. Once the clutch is either snapped in or out there is NO side load on the thrust washers from clutch action.. There can be side load from flat belt usage or main/rod bearing taper wear though. Even severe side hill usage can accelerate thrust washer wear..
As to the cause of a loose flywheel [or loose clutch driver, that�s just as big a problem] I don�t personally believe lugging is the one & only cause as I have lugged my share of 2-cyl diesels without any problems.. While I have no documentation or Deere archive history my personal observation is- the biggest problem with those flywheels coming loose is after service work, or owner flywheel removal as those flywheel pinch bolts are either not tightened enough, or tightened to the yield point, or probably the greatest problem, not re-checked after some hard usage..
The Deere G�s & 70�s are also sort of loose flywheel prone due to large HEAVY flywheels, heavy crankshafts, & severe power pulses [not just lugging either]..
Those flywheels have remained tight on some tractors for many years & in most cases that�s because they haven�t been removed..
Quote: �Also, I have not seen diagrams yet of the clutch assembly but realize that power likely is transferred somewhere from a sideways oriented crank to a front to back oriented transmission gear set�.
--There is a clutch driver [splined to the crankshaft disk] that the clutch plates get pinched against [there�s usually a couple of other floating disks that also spline to that center driver disk].. Once that clutch is snapped in [locked into engagement] all the drive torque goes through that one driver disk that�s splined to the crankshaft & the clutch pulley [clutch drum] spins as if it�s a solid part of the crankshaft.. Once the clutch is locked into engagement you can essentially remove the fork, & all related engagement parts & the tractor will still pull.. That is the beauty of the (simple) Deere clutch, once engaged it drives as a solid unit all by itself so little to no wear is taking place on any of the components..
I hope this explained the flywheel/clutch issue a little deeper.. If you have a additional questions or need more specific information on certain parts of the flywheel/clutch area just post back..
[email protected]
CFWelles
09-13-2004 18:04:52
 Re: 2 cyl diesel flywheels in reply to Clooney, 09-13-2004 07:13:08
Thanks for the comments fellows and especially thanks to Clooney who has taken the time to lend a lot of information to my questions on this and other posts and many others. Clooney, you cleared up what kind of bolts you were talking about in your earlier post when you mentioned grade 8 in your last post. I can understand why you would be stating this in this kind of application. Only thing that worries me here is your comment about bandaiding the disk situation for a quick sale. Although I am fairly quick to understand and learn these issues, I just don't have the experience on this machine to spot some hidden issue. Will try my best to look this over and start this up cold, warm up, and run it good up through the gears as you told me to do in an earlier post. Any of your fellows from Nebraska? Also, no comment on end play measurement. Take it that a good dial indicator set up on the frame and bearing on the flywheel while clutch is applied and let off will do the job? Thought there might be a trick here where you could use a feeler guage for example for a quicker check.
Clooney
09-14-2004 03:29:31
 Re: 2 cyl diesel flywheels in reply to CFWelles, 09-13-2004 18:04:52
CFWelles, you ask..
Quote: "Although I am fairly quick to understand and learn these issues, I just don't have the experience on this machine to spot some hidden issue"
-- If a person hides the repair with intent to defraud even an expert can be fooled.. If there are more tractors around the sellers place look at those for signs of in-progress repairs or quality.. Look at the sellers truck, home etc.. If everything is a mess but the one tractor being sold question that tractor..
Quote: "Also, no comment on end play measurement. Take it that a good dial indicator set up on the frame and bearing on the flywheel while clutch is applied and let off will do the job?"
--Yes, a dial indicator will work good. That is difficult to use on a for sale tractor as it requires removing the flywheel cover or at least the center cover & set-up time.. Probably the easy [re. Quick] way is to snap the clutch into engagement,, then work the hand clutch lever front to rear without actually disengaging the clutch,, then watch the clutch pulley to dust shield gap.. A slight pulley side to side movement is normal [about a match book cover thickness or less].. If you see any measurable movement [like 3/16� & up] suspect excess end play in either the crankshaft or clutch driver disk [both can mean problems but].. If you get a pronounced CLUNK/CLUNK when working the clutch lever front to rear suspect excess end play or a loose clutch driver.
Just finding excess crankshaft end play doesn�t mean the tractor in no good it just means there is excess end play & further investigation is in order.. If I were buying a 2-cylinder Deere diesel & found excess crankshaft end play I wouldn�t buy that tractor without being allowed to pull the flywheel cover for a look at the flywheel to crankshaft area..
[email protected]
CFWelles
09-14-2004 04:44:56
 Re: 2 cyl diesel flywheels in reply to Clooney, 09-14-2004 03:29:31
Thanks for your comments. I am going to take the time to pull the cover and inspect the flywheel carefully. I just successfully won an original John Deere parts manual for this machien on an Ebay auction. Am going to study this carefully as the seller says that it is well illustrated. Will take the right sized wrench and breaker bar to do a quick check on the anchor bolts for tightness as well. Appreciated your explanation of using the hand clutch lever to do a quick check. I, too, look for the conditions around the tractor. The farm looks beautiful in the background with buildings in good condition and no garbage or dead metal laying around. Pleased that you made this comment as I use this a a first indication of the maitnenance attitudes of the seller. This machine supposedly had a major about 400 hours ago, so I expect to see good combustion, no endplay problems and everything about he engine in order. Also on Ebay you can get to judge the persons previous deals though pictures and feedback. This seller has put together some great equipment with postive feedback from the buyers. In this case, he bought this tractor from the previous owner's son as the owner died. I will ask the seller for the name and number of the tractor's first owner's son and speak with him. Everything looks in order here, but your cautions ahve been much appreciated.
SL
09-13-2004 08:21:03
I read this and then went and checked my 720D. I only just got in the seat and moved the hand clutch a bit while its in the full forward location. When I moved it, I noticed that the belt pully would move back and forth a bit, and I am pretty sure I hear the flywheel bumping the flywheel cover on the other end as well. I am not pulling the hand clutch far, just a bit of pressure.
Is it hooped? Still runs fine, it baled a few weeks back with no problems.
Clooney
09-13-2004 09:38:16
 Re: 2 cyl diesel flywheels in reply to SL, 09-13-2004 08:21:03
SL, you ask..
Quote: "I only just got in the seat and moved the hand clutch a bit while its in the full forward location. When I moved it, I noticed that the belt pulley would move back and forth a bit, and I am pretty sure I hear the flywheel bumping the flywheel cover on the other end as well. I am not pulling the hand clutch far, just a bit of pressure. Is it hooped?"..
--You might just need to re-set the crankshaft end play.. That clunking you hear might just be the crankshaft bumping on the thrust washers..
It sure would be a good idea to remove the flywheel cover & check the bolts & for signs of a loose flywheel.. In a lot of cases if you catch the problem early enough you can stop any damage by installing grade 8 bolts, hardened nuts & re-torquing the bolts a few times as the flywheel seats in..
If you can�t hear the flywheel hammering with the engine running with the clutch released it probably isn�t too bad YET..
There is also the slight possibility you have a loose clutch driver disk as that will also allow engaged clutch pulley movement..
[email protected]
