60 PTO Lever-Proper operation?
Fred from MO
09-12-2004 19:07:15
Being new to the PTO on my 60, I have a simple question how does it work?. It has live PTO. I can run the PTO, but I have to pull the lever up to keep the PTO spinning. Isn't it supposed to lock into position? I am sure old farmers in the 1950's did not ride around holding the PTO lever up when they brush hogged. I can pull the lever all the way up and it hits the out cropping on the battery box where the pin goes through. Is there an adjustment I am missing?
Mike M
09-13-2004 06:17:18
 Re: 60 PTO Lever-Proper operation? in reply to Fred from MO, 09-12-2004 19:07:15
You can try to shorten that rod at the bottom there should be a clevis end threaded on.Then it may hit bottom ? More than likely you may have to get rid of any lost travel from worn pins and parts.
