1955 60 Ready to start painting and reassembly
jdman60
09-12-2004 18:11:55
third party image
This is my "60" I only have a little bit of cleaning to do and I can paint it and start to put it back together. Boy this is a lot of fun when you get this far in.
Clooney
09-13-2004 07:39:48
 Re: 1955 60 Ready to start painting and reassembl in reply to jdman60, 09-12-2004 18:11:55
third party image
jdman60, that's not far in.. It can still roll on it's own..
As long as you have it that far down it would be a good idea to re-seal the axles as mentioned below & check the trans gears & clean the trans & engine cases out..
I usually tear them all the way down then start with a clean trans case & build up from there.. That way you don�t get any nasty surprises after it�s back together & fully painted.. If you have to go back in after painting to do any trans or axle work you won�t be easy to be around for a while..
Clooney
JDMAN60
09-13-2004 13:21:45
 Re: 1955 60 Ready to start painting and reassembl in reply to Clooney, 09-13-2004 07:39:48
Clooney, I already have the rear axle seals those and the drawbar frame are all that I was going to remove from this point. I do have a question for you. I have had this tractor for about 2 1/2 years and torn down to this point gets to all the oil leaks I have ever had. The only gasket left on it is between the rear axle hsg and the main case (no leak there ). The transmission only made a small amount of gear noise. Can all the noise ever be removed from one of these when the are 50 years old? All of the bearings in the transmission seem to be okay. Would it be that much better to replace all the bearings? I cannot really tear down to the point you are with your "A". I can clean and paint this tractor from the point I am and make it look pretty good. Thanks for your input jdman60
Clooney
09-14-2004 03:38:48
 Re: 1955 60 Ready to start painting and reassembl in reply to JDMAN60, 09-13-2004 13:21:45
JDMAN60, you ask...
Quote: "The transmission only made a small amount of gear noise. Can all the noise ever be removed from one of these when the are 50 years old?"
-- Not really, those transmissions have straight cut gears so are noisy by design.. Some are just worse than others due to wear, or shaft spacing, or bearing wear..
Quote: "Would it be that much better to replace all the bearings?"
--Only if they are worn or bad.. If the bearings are good then just leave them.. Problem is, a bearing can look good but have worn rollers or balls inside that can�t be seen from the outside. I remove all the bearings & clean them then spin them by hand & look & listen for grinding, roughness, looseness, excess ball to race clearance.. I don�t know how you can tell if the counter shaft inner bearings are any good without completely removing the counter shaft. Those bearings are found bad in an awful lot of tractors I work on..
[email protected]
Jason Z in MO
09-13-2004 12:05:43
Clooney,
Man, you can eat off that case!
Couple of questions:
It looks like it has a sealer applied?
Do you mask off the gasket surfaces before priming / painting or do you assemble before any paint is applied?
Clooney
09-13-2004 12:17:45
 Re: 1955 60 Ready to start painting and reassembl in reply to Jason Z in MO, 09-13-2004 12:05:43
Jason, actually that is just a freshly cleaned bare case.. Done using a rotary wire brush, air powered needle scalar & smaller end rotary wire brushes on a die grinder.. I will not sand blast an engine case for fear of not getting all the sand out of the holes & casting pores.. Once it is cleaned I go over it with a diluted Phosphoric acid to kill the rust then another wire brushing.. At that time it starts to look like new.. The paint also sticks better on the etched metal..
I have done enough of those old Deere tractors now to have a pretty good system worked out for cleaning & metal prep..
Clooney
Mike M
09-13-2004 09:47:40
Now that's the way I like to see them ! Glad to see someone else knows what a restoration is. It's alot of work but you do end up with a tractor that functions better and longer than most.
Clooney
09-13-2004 10:21:25
 Re: 1955 60 Ready to start painting and reassembl in reply to Mike M, 09-13-2004 09:47:40
Mike, that's the only way I feel comfortable about not having missed anything. It also makes it much easier for me to clean all those nooks & crannies of years of crud, rust, & dried grease..
As you have probably also found it�s a lot easier to tear them all the way down the first time than to go back in later after it�s assembled..
I can�t ever remember tearing one all the way down to bare case that I wasn�t glad I did because of finding a hidden problem like a bad trans bearing, or small crack, or caved in oil filter can.. On this �A� all the trans gears were in great shape but over � the bearings were worn out.. It also was in dire need of an oil filter can as the top way pulled way out of shape.. It also needed a PTO gear shaft bushing [a lot easier to replace at this stage of teardown]..
Probably one of the harder full tear downs was a loaded 720 diesel as I had piles of parts ALL OVER the shop [there�s a lot of pieces in one of those babies].
Clooney
Mike M
09-12-2004 19:19:08
Your all most there. Might as well pull the axles and reseal them and put in a new gasket where the axle housing bolts to the main case to prevent future leaks.
Jared
09-12-2004 20:33:20
 Re: 1955 60 Ready to start painting and reassembl in reply to Mike M, 09-12-2004 19:19:08
mike m is right, it would be a shame to have to tear the tractor apart again after it has been repainted .
