60 Noise
Jason S
09-12-2004 14:58:13
I HAVE A JOHN DEERE 60 THAT HAS A PRETTY LOUD WHINE IN IT AT TIMES. IT DOES IT IN FORWARD OR REVERSE BUT ONLY WHEN THE TRACTOR IS UNDER A LOAD. IT IS QUIET WHEN GOING DOWN HILL. IT IS ALSO QUIET WHEN OUT OF GEAR WITH THE CLUTCH ENGAGED. I HAVE PULLED THE CLUTCH OUT AND ALSO REMOVED THE MAIN SIDE COVER. EVERYTHING LOOKS GOOD AND ALL THE GEARS IN THE SIDE ARE IN GOOD SHAPE. ANY HELP OR IDEA'S WOULD REALLY HELP. THANKS VERY MUCH
Clooney
09-13-2004 07:27:55
 Re: 60 Noise in reply to Jason S, 09-12-2004 14:58:13
Jason, if that whining noise is at engine speed & not specifically in any one gear range it is usually due to gear tooth wear on both the drive & driven [1st reduction both the clutch pulley gear & large gear] � What happens is the tooth crown wears flat so the angle of engagement becomes skewed & causes the whine.. It is really hard to see the flat tooth wear as just a slight amount of wear will cause the whining noise..
In most cases that whine won�t cause any harm & even some new Deere tractors came with a fairly pronounced gear whine..
In some cases using 90 weight or even 140 weight GL-1 gear oil will help quiet the gear noise a little.. The old GL-1 mineral based gear oil will stick to the gear teeth better than the newer GL-2 through 7 gear oils & the straight weight 90 weight gear oil is much thicker than any of the newer 80W90 or 80W140 gear oils.. Keep in mind that using GL-1 gear oil won�t remove the gear noise but it CAN quiet it some though..
If you have any clutch pulley bushing or bearing wear take care of that as wear in those places allows the clutch pulley to snap into engagement off center slightly.. Even crankshaft main bearing wear can effect gear noise if it allows the tooth engagement to change from it�s worn in position..
If your trans input shaft bearings �either inner or outer] are worn that can also effect gear tooth engagement & line up also so look for wear there..
[email protected]
