JD 112 Fuel Variator???
JTWalk
09-12-2004 14:00:07
I've got the variator off the tractor and my question is...How freely should the center sheave slide on the hub,and is there anyway to oil this.I noticed slight rust on the hub that is streaky & around the ends of the hub where the two outer halves go , but it is still shiny for the most part. Also,I've got the original manual and it recommends leaded gas. Is there any thing I should be adding to the gas(unleaded). I don't think any additives have been used before and I don't want to damage the engine.Thanks
Mike M
09-12-2004 19:24:43
 Re: JD 112 Fuel Variator??? in reply to JTWalk, 09-12-2004 14:00:07
That center sleeve should be free and have no oil or grease and don't use any belt dressing on those belts either.You can take it apart and shine it up with some emery cloth. I forget how they come apart I think they unscrew. I would not worry about the gas as it probably has been running for the last 20 years on unleaded.
