2350 OVERHEATING
VKG
09-12-2004 13:10:22
CUTTING HAY FRIDAY NOTICED TEMP. GAUGE IN THE RED IT NORMELY RUNS A LITTLE WARM BUT NOT IN THE RED. OPENED THE RADIATOR CAP AFTER IT WAS HOT NO PRESSURE AND COULD'NT SEE ANY COLLANT CIRCULATING THE COLLANT WAS JUST STILL IN THE NECK. MY GUESS IS THAT THE THERMOSTAT IS STUCK. GOING TO TRY TO FIX THIS WEEKEND. ANY IDEAS WOULD BE VERY MUTCH APPRECIATED.BEFORE I GET INTO IT.
THANKS , VKG
R. John Johnson
09-12-2004 20:54:38
 Re: 2350 OVERHEATING in reply to VKG, 09-12-2004 13:10:22
Don't know if it would be the same cause, but our 2755 had a similar problem. Turned out the plastic impeller in the water pump self destructed and was not pumping coolant . What gave it away was a small leak out the bottom of the pump when everything got hot. If it is a thermostat, be careful with the housing. The one on the 2755 was plastic. I think you can guess what happened when I tightened the housing down.
Good Luck
John
