3010 oil pressure
Brad B
09-12-2004 05:09:17
Oi pressure light comes on at 800 RPM. I have adjustment turned all the way up. Is there a rebuild kit for the pump? Or do I have to replace it? Thanks again.
msb
09-12-2004 09:49:22
 Re: 3010 oil pressure in reply to Brad B , 09-12-2004 05:09:17
It coul also need new bearings(rod,main and or cam bearings) instead of a rebuild of the oil pump.No way to know without a teardown.look the oil pump drive gear over real good.Are the teeth sharp?You may have to replace the cam too.
Brad B
09-12-2004 10:33:57
 Re: 3010 oil pressure in reply to msb, 09-12-2004 09:49:22
Not what I wanted to here but that's why I asked. Thank You.
Bob
09-12-2004 11:22:44
 Re: 3010 oil pressure in reply to Brad B , 09-12-2004 10:33:57
Before getting too excited, get a known-good mechanical gauge hooked up temporarily, and see what the oil pressure really is.
I dealt with this about a month ago. The official Deere pressure spec. is not as high as one might think, but I can't remember it at the moment. If no one else posts the pressure spec., I'll look it up tomorrow and post it.
msb
09-12-2004 20:02:03
 Re: 3010 oil pressure in reply to Bob, 09-12-2004 11:22:44
Bob gives good advice here.I should have said the same.Always use a master gauge when checking oil pressure.
