3010 three point
Brad B
09-12-2004 05:02:17
My lift arms will not stay up when tractor sits with no load and not running. I would like to fix it. Is it a big job? Thanks for any info.
msb
09-12-2004 09:56:56
 Re: 3010 three point in reply to Brad B, 09-12-2004 05:02:17
I would start out by replacing the o-ring and back up washer on the 3 pt. piston.Its located in the rear just below the seat.Remove the hydraulic oil line.Then remove the 4 capscrews,3/4" I think.Raise the arms by hand and push the piston back in the cylinder bore and then with a swift move,quickly slam the arms down.That should pop the piston out in your hand.Not a big job.Just be sure to liberally grease the new o-ring aand be sure it is not twisted when you install it in the groove.
If that doesn't fix it, then the thermal relief valve needs to be reseated.
Freddy
09-12-2004 06:35:23
I am working on a 2510 that does the same thing. As soon as the engine is off the 3 point comes down.
