60 decal location
Fred from MO
09-11-2004 19:40:59
I am putting on my final decals but 2 that came in my decal kit have me confused as to there proper location on the tractor. One is a yellowish decal that says "Custom Powr-Trol"
and the other is a very small green decal that says something like "valves must be closed before starting engine". Anyone that knows for sure where these go I would appreciate hearing from you.
T213R
09-12-2004 06:53:47
 Re: 60 decal location in reply to Fred from MO, 09-11-2004 19:40:59
Congratulations on buying the "El Cheapo" decal set from some place like Tractor Supply! Your 60 was never equipped with CUSTOM POWRTROL, instead having the older John Deere HYDRAULIC POWRTROL (and a different decal) Theclose valves decal belongs on an LP-Gas tractor. The reason your decal set has the WRPNG decals, is that sometime after the 60 was discontinued, John Deere, in order to supply SOMETHING to people who wanted a decal set, assembled a series of "Kit"S using onhand and of the shelf decals they had in stock---and cheerfully replaced correct decals with substitutes which they had, rather than reprint correct ones. These "Kits" were then copied by numerous aftermarket companies,
The way to acquire a CORRECT set, would have been to have bought from TRAVIS JORDE or K&K Antiques, both of whom sell researched, and correct decal sets.
Fred from MO
09-12-2004 15:12:24
 Re: 60 decal location in reply to T213R, 09-12-2004 06:53:47
Yep that is where I bought them!!
CLW
09-11-2004 22:13:13
Fred, the Power-Trol goes below the "Be Careful" plate or decal on the back of the seat, just above the fill cap of the power trol. The other decal should say something like "Keep Valves Closed When Engine is Not Running" These go on the left side of the tractor between the vapor and liquid valves if you have a LPG tractor. They go in the trash if you don't.
CLW
Fred from MO
09-12-2004 04:59:12
 Re: 60 decal location in reply to CLW, 09-11-2004 22:13:13
Thanks. That makes sence. The LPG decal I will trash.
