60 Clutch Problems
Fred From MO
09-11-2004 19:22:13
My 60 clutch has always seemed to act up since I got the tractor. It would not pull unless you forced the lever forward and held it there. The spring pressure to put it in gear was never there as described in the service manual. Then something happened, it worked good for a couple of shifts today, then all of a sudden when you force the lever forward, the clutch would not engage, but if you leave the lever mid way the clutch will pull. Now it is stuck engaged and I cannot pull the clutch lever back to disengage the clutch. Any ideas on what happened. It seems somthing has got stuck in there for sure. I have tried adjusting the clutch and the pully brake. It does not seem to help.
Bryan Breland
09-12-2004 19:12:24
 Re: 60 Clutch Problems in reply to Fred From MO, 09-11-2004 19:22:13
It sounds to me like the clutch collar has broken. It is made out of brass and is actually called a bushing. They are not bad to repair. Just pull the clutch fork out. Make sure that you get all of the broken pieces out of the gear case. Be careful putting it back together. Make sure it goes back in the groove on the clutch unit. I cant remember how much they cost from deere but it is up there. The same one out of a late model A will fit.
BushogPapa
09-12-2004 07:12:47
It could be a broken clutch-facing...
Better pull it apart, and check it..
Ron.
