Clutch Driving disk removal
Tom M
09-11-2004 15:29:44
What type of wheel puller is used to remove this disk? I have a 1939 John Deere B and there are no bolt holes to connect to like there are on latter model B"s.
CRUSADER
09-11-2004 21:05:18
 Re: Clutch Driving disk removal in reply to Tom M, 09-11-2004 15:29:44
Tom, It's been awhile, and if memory serves me correctly. After you have removed the outer plate, you should be able to fit a two jaw puller in/behind the drive disc around the circumference of the center where the nut is that you removed. It's a tight fit, but can be accomplished. Don't do like I did on the first one I worked on and try to remove it by putting the puller on the outer area where the clutches contact the drive. You'll break it and either will have to find a replacement (preferably) or if you have a real good machine and welding shop they can possibly repair it for you.
later days mate,
Jim
