Difference between a JD 40U and 40S?
Bird
09-10-2004 18:08:15
I recently saw a local antique tractor pull in my area and really liked a 1954 John Deere 40U. After going on-line I saw that there were many model variations, but the 40U and 40S look very similar. My question is what are the differences between the two? What would have made someone purchase one over the other? Any information you can give would be appreciated.
andy b.
09-10-2004 20:35:06
 Re: Difference between a JD 40U and 40S? in reply to Bird, 09-10-2004 18:08:15
i have a 40U and a friend has a 40S. they are both pretty similar, as you said. the biggest difference is that on the 40S the final drive housings are turned down, so the tractor sits higher. on the 40U they are turned back so the tractor is lower and longer. the front axle on the 40S is also slightly taller to match up with the height of the final drives. the other differences are pretty small. the fenders are slightly smaller on the 40S and the rear toplink mount is lower on the 40S.
the 40S is more of a "row crop" tractor in that it sits a bit higher while the 40U was a Utility tractor and many times had a loader or other piece of equipment mounted on it. in fact, my 40U came with a Wagner loader. if you wanted to use the tractor for something like cultivating corn, the 40U would be too low. for most other things the tractors could be used almost interchangably.
andy b.
