2010 front loader problems
Tim Withrow
02-04-2004 20:27:00
Duel control loader only goes up halfway and stops, It goes back down but slow and noisey like pressure is holding It back and has no down pressure, also when tilting the bucket it moves up without moving the other lever. I've changed the filter and took the control valves apart and can't find the problem.
Keith Callen
02-05-2004 18:45:36
 Re: 2010 front loader problems in reply to Tim Withrow, 02-04-2004 20:27:00
It sounds like we are having similar problems. I have a 2020 and the loader used to go up and down with no problems until I tore apart the Selective Control Valve for inspection. The bucket always dumped slowly and would sometimes stop all together. I have a feeling that our problem is with the pressure and return valves in the SCV. After I put everthing back together the bucket now moves without even touching the levers. I am going to keep investigateing and if I find anything out I will let you know.
Keith
Hilltopper
02-05-2004 11:59:40
Sounds like your lines are plumbed wrong at the valve. Recheck all your hoses ands see if they are plumbed correctly Only pressure lines should go to valve. Returns go directly to tractor.
Brokenwrench
02-05-2004 04:14:18
You have a restriction in the return circuit. If it is plumbed into the remote on the back of the tractor,check the connections. Quick connects wear out and don't open enough to let the oil flow. If it is tied directly into the tractor look at the return line for kinks or sharp bends,or if you are in a cold climate look for ice in a return line or fitting.
