H running on one cylinder
NHJeff
09-10-2004 06:14:06
Hi, my neighbor is trying to get a 1940 (S/N ~12,000) to run. He says he"s done everything you can think of apart from pistons and rings, but cant get the right hand cyclinder to run. It will run on the the one left cyclinder and he even moves it in and out of the barn on its own power. He had the magnito checked by the dealership and has had the heads overhauled. New wires and gapped the plugs. The only hints I got out of him (I havent been working on the tractor) is that he says it gets "good" compression when turning the engine over by hand but gets "poor" compression when he runs the engine on the other cylinder. I put good and poor in parenthesis because I dont know what pressures he got when he tested.
Any one have any advice?
Thanks,
Jeff
chrisfromsolitude
09-11-2004 18:22:20
 Re: H running on one cylinder in reply to NHJeff, 09-10-2004 06:14:06
I haven't worked on any H's but I wouldn't think they would be much different than the A's or B's. Most A's and B's only ran on one cylinder when they were idling and when you put them under a load the other cylinder would come in. The first piston sucks the gas in and fires and there was no (or very little)gas left for the other one at an idle. When you put it under a load the cylinders would suck in more fuel and both cylinders would fire. As far as the low pressure thing goes I don't know. May have to wait for somebody else to answer that one. Hope this helps a little.
