Toby, You can still test each battery one at a time with whatever type tester it is you have. (Maybe only one is weak, you have a load type tester??) First make sure the belt is tight and not glazed!!!!! !!!!! and wire connections tight. Anyway, if you have a voltmeter, if the charging system is working and BOTH batteries are good with no bad cells, at fast throttle, the battery voltage on both the individual 12 volt batteries should rise from around 12.6 to 13 or a lil better or approx twice that across both in series (outermost untied posts leading to starter). Also, the lights should glow noticeably brighter between idle and fast throttle. NOTE: 12 volt lights are fed from only one of the batteries, so if that particular battery is weak or bad, the lights may not brighten or the voltage may not rise at fast throttle even if the generator is otherwise good. On those dual battery series 24 volt systems, if EITHER battery is weak, it weakens the system and possibly the charge rate. Make sure all cells have electrolyte above all the plates and none have a gray or milky apperance which is indicative of a bad cell. If possible, have both the batteries load tested at a battery shop, that will tell you a lot. To be safe, if any connections/terminals appear suspect, I would remove, clean and wire brush, and reatatch the connections on the generator and regulator etc. You might check the generator brushes to make sure they are not worn too short and that the hold down spring assemblys are free and push the brushes tight down against the commutator. Check BOTH batteries individually first (maybe ones bad) and the belt tightness and connections and see how much the voltage rises on both batteries at fast throttle, you may just have one weak battery dragging you down. Post back or e mail [email protected] any questions, let us know, good luck n God Bless John T
