Best sight I ever saw!!!
jdjoe_indiana
09-09-2004 19:12:47
Driving the 730D this evening heading west as the sun went down between the air stack and muffler. Breath taking!! Wanted to thank you guys and especially Clooney on the help with the electrical system. I installed the two 975 CA Interstate's this evening (which I might ad is the biggest possible hunk if battery that would fit, almost had to trim one to get it in!!) and spun the beast over and she was running in 5 sec. flat!! WOW. I love it! Still have to find that short I have in the accessories. I know I will have many many more questions in the future. Thanks for all your help! One I have on my mind right now is what should be the battery voltage when the system is charging? I just want to make sure that regulator is working. One other dumb question, should a guy decompression the engine on shut down when the throttle is in the fuel off position? Thanks Joe
Joe P.
09-10-2004 05:31:56
 Re: Best sight I ever saw!!! in reply to jdjoe_indiana, 09-09-2004 19:12:47
We used to decompress on the last few revs also. I don't remember why Dad did it but now I know that any time you can reduce stress on something, it will live longer (machine and man.) Each rev it makes with no compression, it adds a liiiii iiiii ittttt ttle life to head gaskets, rings, bearings, valve seats, etc.
Clooney
09-10-2004 03:24:33
Jdjoe, you say..
Quote: "I installed the two 975 CA Interstate's this evening (which I might ad is the biggest possible hunk if battery that would fit, almost had to trim one to get it in!!) and spun the beast over and she was running in 5 sec. flat!!"
--That's a lot of cranking power.. Post back after the weather gets cold [if you use the tractor] & let us know how it starts in sub 30�F temps..
Quote: "Still have to find that short I have in the accessories"
--Use that test light between the center battery ground wire & the chassis then do the starter, generator disconnect I spoke about in the first post. In the mean time just install a switch in that wire & turn it off when done with the tractor for the day.
Quote: "I have one (thing on) my mind right now, what should be the battery voltage when the system is charging?"
--A little over 27 volts.. Most will charge at or around 27.5 volts give or take a little. It at least needs to be over 25.2 as that is base battery voltage with fully charged batteries.
Quote: "should a guy decompression the engine on shut down when the throttle is in the fuel off position?"
--It�s probably not a bad idea.. I wouldn�t decompress the entire time the fuel shut-off is pulled just pull the lever & decompress the last few revolutions. I have my doubts that decompressing helps flywheel retention as those last few strokes are pretty soft compared to the firing pulses when the engine is lugging but do agree with Chuck that it does allow the flywheel to stop in a different location & that is a big help to those flywheel ring gear teeth..
Those are really nice tractors & I think you will really like it.. Just get that wiring problem solved before you run those batteries down as those new batteries only have a limited number of complete run-down-re-charge cycles before they start to weaken..
[email protected]
Chuck in Ks.
09-09-2004 20:31:59
jdjoe, You don't need to use the decompression lever on shut down, however, I do. If you don't use the d-lever the engine stops at pretty much the same place each shut down. Using the d-lever on shut down (after fuel is shut off) allows the engine to stop at a different place. This lets the starter engage the flywheel teeth at a different place each time and this should extend the life of the flywheel teeth.
Chuck
msb
09-09-2004 19:52:21
No reason to decompress on shut down.It is a good idea to use the decompression pedal when starting.You sure brought back some memories of a young man not quite 21(me) who had just bought one of the last 730 Diesels sold by Reynolds Farm Equipment.Thought I had died and gone to heaven.Drove it right of the showroom floor.If I remember right,I paid $5,600 for it.$1,200 for a new 666 5-14" tip standard plow to go with it.
Mark Mixdorf
09-10-2004 02:44:32
 Re: Best sight I ever saw!!! in reply to msb, 09-09-2004 19:52:21
Decompression at shutdown could be a good idea for another reason. The flywheels on those big engines loosen up and ruin splines by nature. But if the engine were to just "spin down" upon shut down rather the shock of hitting a compression stroke, could lessen this effect. Probably minimal but something nonetheless.
