JD 50 Live PTO clutch...FRUSTRATION!!!!
Chuck McDonald
09-09-2004 18:01:48
Hey
a few months ago i tore the entire clutch apart and put new springs in as well as new laminated clutch disks. However, i did not replcae the driving (metal tabbed) disks that go in between them. I cannot get the cluch to keep from slipping horribly(!!) when placed on a load. You probably could stop it with your hand its so bad. I have run the adjuster all the way to the back (turning it counter clockwise) and the lever becomes very hard to pull up, so hard it will not go over center, however the clutch still slips. Should I have replaced the small metal disks inbetween the laminated disks, or do you think i put a disk in backwards and it cannot grip? I was sure it was together right. The only problem I had in reassembly was i cannot see the brake at through the second (back) hole in the pto housing where you are supposed to adjust the clearance. The book said somethign about some shims. I didnto understand and could not figure out how to engage it on the workbench as the new springs made it very difficult.
Can someone please help. I have over $200 in this clutch and it still doesnt work. The tractor is around Macomb, IL if yall are near to come look. Please help. Thanks
Chuck McDonald
Mike w J
09-10-2004 07:42:35
 Re: JD 50 Live PTO clutch...FRUSTRATION!!!! in reply to Chuck McDonald, 09-09-2004 18:01:48
My 60 did the same thing when I adjusted it I got it a little to tight and the snap ring on the front of the clutchpac came off it ruined the shaft it was on an early 60 not sure if they are the same the later ones had an update but i'm not sure what it involved
Clooney
09-10-2004 04:11:18
Chuck, first & foremost make sure you don't have trans gear oil from the main trans entering that PTO area & polluting the PTO oil.. Trans gear oil will really cause your clutch to act up.. Drop the PTO oil & give it a good sniff [you know the gear lube sulfur type smell].. If you have gear oil in that PTO housing your PTO lube pump seal is leaking.. That pump is on the front of the rear housing so the entire rear of the tractor will have to come off.
Next, if your 50 has a PTO clutch fork over-travel adjuster bolt make sure that is set correctly [it�s adjustment is in your service book].. I don�t have a book handy & can�t remember if the 50 has that over-travel stop or not.. If you have one it would be sticking out of the top of the PTO housing [bolt with a jamb nut]..
If you didn�t set the shim height there is no way of knowing if your clutches can be pushed tight enough together to not slip.. You really need to set [or at least check] the shimmed clutch pack height. Read the book again then post back [or E-Mail me] on exactly what part you don�t understand..
You also need to set that PTO brake travel as that is what controls PTO clutch pack clamping force but if you set that clutch so tight you could barely engage it that probably isn�t the problem..
You probably should also replace the clutch apply springs as weak springs can adversely effect the clutch clamping pressure. Those springs weaken quickly if the PTO clutch slips & makes much heat..
Usually the number one reason that a PTO slips that has new clutch plates installed is trans gear oil in the PTO housing, so check that & if you don�t have gear oil in the PTO post back with questions on the book assembly procedure..
[email protected]
Chuck
09-10-2004 06:16:20
 Re: JD 50 Live PTO clutch...FRUSTRATION!!!! in reply to Clooney, 09-10-2004 04:11:18
I am sure there is no trans fluid back there as I have replaced both seals on the pum/pto shft between the two cases. Also, i dont have a travel adjustment on the top of the case. I did not adjust the shim highth. What is the importance and how do you tell when it is at proper highth? Finally, I did replace the three springs in the clutch. I believe those were the springs you were referring to.
The only thing that worries me is that I cannot see the brake lining in the back hole on the housing. If i had adjusted the shims, would that have been able to check through that hole?
Thanks
Chuck
Clooney
09-10-2004 11:15:03
 Re: JD 50 Live PTO clutch...FRUSTRATION!!!! in reply to Chuck, 09-10-2004 06:16:20
Chuck, you say/ask..
Quote: "Also, I don�t have a travel adjustment on the top of the case"
--I got a chance to look at lunch time & the 50 prior to S/N 5029199 had that fork stop bolt.. If your S/N is after that then you probably don't have it..
Quote: "I did not adjust the shim height. What is the importance and how do you tell when it is at proper height?"
-- The shim height controls how much free play you have in the clutch pack & also controls how tight the clutch stack can be squeezed together when the PTO clutch is snapped in. As far as setting it, it is spelled out pretty clearly in the service manual.. I would do a lot of typing here & not really tell you anything different than the manual does.. Re-read the manual & post back ANY & ALL questions you have on that adjustment.. It will be much easier to do it that way..
Quote: "Finally, I did replace the three springs in the clutch. I believe those were the springs you were referring to"
--That could actually be your problem right there.. Those (3) springs are the RELEASE springs that try to hold the clutch apart.. There are either 8 or 9 APPLY springs [depends on your S/N] that hold the clutch compressed when the clutch is snapped in. If your apply springs are weak from heat & you installed new [read stronger] springs on the release side that could make the apply springs do even less if they are sacked out from heat.
I would suggest you re-read the service manual,, then post back or E-Mail so we can help you understand the shim setting procedure.. Then pull the clutch back out & replace the 8 or 9 apply springs & set the shimmed height to reasonably close to the spec..
On seeing that PTO brake? You don�t need to.. All you need to do is see the clutch cam as that is what moves & must be measured..
I will be gone AGAIN for most of the weekend so if you post back & I don�t respond start a new thread on late Sunday or Monday [refer to this thread] .. I will eventually respond to an E-Mail request but have been receiving over 50 tractor related E-Mails a day & only answering about 10 or 12 so am now well over 400 behind & climbing daily.. [I�ll catch back up when the weather gets cold outside]..
[email protected]
