JD 50 Distributor Again
BillS
09-09-2004 10:57:50
Ok got the rotor shaft extension piece on right (had to try it the wrong way first)and I did have it running a little but ran out of time to mess with it. I noticed when I was putting the points breaker plate back on that it could be set just about anywhere. It there a trick to getting it adjusted in its arc correctly? I have a sneaking suspicion it is pretty critical to make it run right. I just put it on where it looks like the screws had been before but it is kind of hard to tell as I wire brushed all the rust off of it. Also is there a difference in condensors? The one that was on it was all rusty so I put a new one on it that I got in a box at an auction with some other new in package JD parts. The fellow that had it had some old JD two cylinders and it looked pretty much like the one I took off. Thanks for all your help folks.
BillS
09-10-2004 11:08:29
 Re: JD 50 Distributor Again in reply to BillS, 09-09-2004 10:57:50
Thanks Duane, I found the little marks and lined them up. Tractors runs, but not the best. I noticed a little sparking btween the spark plug wire conduit and the spark plug cover so the wires must be shot. Looks like another trip to my local John Deere dealer..... Also looks like the throttle shaft in the carb is loose as when the governor pushed the throttle open to keep it running it jiggles. I hate to think what a carb rebuild would set me back.
Duane Larson
09-10-2004 11:27:53
 Re: JD 50 Distributor Again in reply to BillS, 09-10-2004 11:08:29
BillS,
There are alternatives to your JD dealer, sometimes but not always cheaper. Do you have a Tractor Supply store around? They sell sets of plug wires, and I believe www.brillman.com probably sells plug wire also.
If you think only the bushings need replacement on your carb, that is not hard - kits include bushings, a new throttle shaft, and a needle and seat, and shouldn't cost more than $20 (normally less).
Duane Larson
09-09-2004 12:09:07
BillS,
There will be a line stamped in the upper left side of the breaker plate which holds the points, and an index mark on the left hand side by the clamp screw. These two lines need to be aligned.
Yes, the condenser needs to be matched with the coil to minimize metal transfer at the points, and provide the best spark available. Condensers used in Wico magnetos and distributors range from 0.2 mfd to 0.34 mfd, so you should get the correct one. Can you provide a part number from the new one? That way we can tell if it is correct. As I recall the capacity is at the higher end of the range, but I will check my shop notes and post back.
I also added a response to your earlier post about bushing wear.
Duane Larson
09-09-2004 12:27:50
 Re: JD 50 Distributor Again in reply to Duane Larson, 09-09-2004 12:09:07
BillS,
The capacity of the condenser is 0.30 - 0.34 mfd, and the index mark is in the lower left hand side of the breaker plate, not in the upper left side as I stated in the previous post. And the index mark in the case is in a corresponding location.
