G cylinder walls
oldiron 48
09-09-2004 09:33:39
I have A G john deere block that has damage in the #2 hole, my question is would it be better to sleeve the block or bore it out.also if I bore the block .125 over size will it run hot.
Goodwrench
09-09-2004 11:51:01
 Re: G cylinder walls in reply to oldiron 48, 09-09-2004 09:33:39
If the block will clean up at .125, bore it. The trick is ensuring it will clean up before purchasing your pistons, as you will want to bore your block to fit the pistons. Don't bore to .125 & then add pistons, as clearances are important with aluminums (or any piston) to achieve maximum performace and minimal wear/oil consumption.
Unless the cooling system is scaled tremendously, the "G" will not generate excessive heat under load at .125 over. If all you are looking to do is light work / parade duty, the cooling capacity of a "G" will cover many sins in radiator / block / head cleanliness.
