Clooney, D clutch
Paul.D.Canada
09-09-2004 07:30:02
If I pull back on the clutch lever and clutch tries to engage again, does this mean that I have to adj. the pulley brake tighter? And is there a break in period for new linings to re adj. them? Thanks alot for all your help, Paul
Clooney
09-09-2004 07:44:25
 Re: Clooney, D clutch in reply to Paul.D.Canada, 09-09-2004 07:30:02
Paul, you ask..
Quote: "If I pull back on the clutch lever and clutch tries to engage again, does this mean that I have to adj. the pulley brake tighter?"
--Yes, a loosely adjusted pulley brake can allow the clutch to partially re-engage when the lever is pulled farther to the rear. At least start with a brake adjustment as that usually corrects the problem..
Quote: "Is there a break in period for new linings to re adj. them?"
--No given time or usage period.. It really depends on the texture of the drive & driven parts & type of usage.. Just run it until the snap in pressure on the hand lever gets low then do a re-adjustment.. I usually like to start again after some usage & re-torque the nuts to a given value with the clutch engaged to even out the apply pressure [probably around 10-15 foot pounds.. Then do a full re-adjust while keeping the nut turns [or partial turns] even in count..
[email protected]
