JD 112 Variator /Clutch Problems
JTWalk
09-08-2004 19:20:11
Had trouble with tractor accelerating with the variator in the forward position.If I pulled BACK on the clutch/brake pedal the variator would drop back and the tractor sped up,but the C/B pedal is way higher than the 7 to 8 inch maximum distance allowed to the footrest. Then when the pedal is pressed to slow down, the variator drops back down into slow speed. Checked into adjusting the clutch override, and noticed the eyehook that attaches to the variator arm is bent. Is this my problem or is this a effect of a bigger problem?Thanks ahead!
Mark A.
09-10-2004 13:34:32
 Re: JD 112 Variator /Clutch Problems in reply to JTWalk, 09-08-2004 19:20:11
Perhaps someone before you had a belt go bad, and forced the variator handle or clutch pedal to loosen it and it got bent at that time. Otherwise it's hard to know. They haven't been built since 1974.
Mark A.
09-09-2004 10:40:14
Sounds like the spring is missing that goes from the variator and hooks back by the transaxle. To adjust that variator. Start the tractor and let it run, put the lever in the fifth notch on the quadrant, below the lever there is a plug, may be missing by now, you will find a bolt head that will take a 3/4" socket, loosen that until the clutch pedal comes to the top of it's travel and then tighten. That spring needs to be there to make it work properly. It attaches to that variator by a short link.Maybe that eyehook you're talking about.
JTWalk
09-09-2004 16:01:08
 Re: JD 112 Variator /Clutch Problems in reply to Mark A., 09-09-2004 10:40:14
Thanks Bob. The variator spring is still intact to the rear.The spring itself seems fine.Very tight. The eyehook that is bent is attached to the top of a shaft that goes inside a heavy duty spring,and is shown in the manual as a 'clutch override'. At the end of this shaft there are holes to stick a awl in to adjust the clutch/brake pedal height. The link you describe is connected to the clutch pedal and the 'clutch override' at the same point. I guess what I am wondering is. What could have caused this eyehook to bend?
JTWalk
09-09-2004 16:04:39
 Re: JD 112 Variator /Clutch Problems in reply to JTWalk, 09-09-2004 16:01:08
Sorry. I meant 'Thanks Mark'
