JD 50 Wico Distributor
BillS
09-07-2004 22:54:03
My 50 after sitting for a few months wouldn't start, took the cover off of the distributor and the points were a mess and the mechanical advance system was all rusted and froze up. I took the little stub shaft piece that the points ride on to get to the timing advance stuff to clean it up and now I noticed it can be put on wrong and have no idea which way to put it back on. Whats the easiest way to do this. I figured I could probably pull the air intake, pull the carb, pull the valve cover, turn it over till both valves are closed on one side and put the distributor back together with the rotor pointing to that cylinder then put it all back together but thought you folks might know of an easier way. I never did take the distributor completely off. Any help or ideas are appreciated.
Duane Larson
09-09-2004 07:14:10
 Re: JD 50 Wico Distributor in reply to BillS, 09-07-2004 22:54:03
BillS,
You might also want to check the shaft (to which the cam attaches) for looseness. If you can wiggle the shaft with the cam off any it is loose and either it or the bushings are worn. If the bushings are worn the shaft/cam will wiggle around and the points will not open at the same time each revolution, depending upon the cam/shaft position in the worn bushing - they are only $4.20 each, and will have a big effect on your distributor operation. The shaft is no longer available.
Jim Nauert
09-08-2004 18:37:07
I have the original owners manual for a xb distributor and it says, First remove the spark plug on the flywheel side place your finger over the hole and rotate the flywheel in the running direction until you feel a presure of air in the cylinder continue turning the flywheel slowly until the punchmark on the flywheel hub lines with the V grove on the flywheel gaurd in this position the slot in the coupling on the govoner shaft will be horizontil. with the distributer held in your hand conect the lead wire from the switch to the distributer and insert one end of a short piece of wire in the upper terminal of the distributer cap ground the distbributer on the crank case cover and bend the free end of the short piece of wire to within one eighth inch of the bolting flange of the govenor. rotate the driving lug slowly in a counter clockwise derection stop instantly when spark occours between the end of the wire and the bolting flange on the govenor driving lugs will be in a horizontal position. replace distributer and gasket on the govenor case making sure the driving lugs engage the slots on the drive coupling after tightining the two cap screws with your fingers rotate the top of the distributer towards the front of the tractor as far as posible line the punch mark on the flywheel hub exactly with the V groove on the flywheel gaurd (this should already be done) tap the top of the distributer toward the back of the tractor a little at a time until a spark is prodused at the eighth gap between the short wire and botling flange tighten the tap srews holding the distrbuter to the govenor case and install spark plug cables left hand spark plug cable must be installed in upper distributer cap terminal. I don't have a scanner but if you give me your address i can mail you a copy
BillS
09-08-2004 22:03:14
 Re: JD 50 Wico Distributor in reply to Jim Nauert, 09-08-2004 18:37:07
Thanks guys, I should be able to figure it out from all your good info. Went down to JD dealer today to get new points and some of the mechanical adnvance springs. $21.25 for points and 13.99 EACH for the dinky little advance spring. UNbelieveable. I thought my 57 Chevy was expensive to work on.
John T
09-08-2004 07:43:21
Bill, Basically all you have to do is install it so the rotor tip is lined up n pointing to where the caps tower/terminal would be that connects to the left cylinders plug wire when its at TDC where the distributors cam is opening (raising) the points. That way when she fires (points break open) the spark is routed to the left cylinder when its at TDC.
You can remove the left plug and as the engine is slowly rotated (both plugs out to ease turning) and feel when shes coming up on compression (building up pressure out the plug hole) and find n stop when the pistons at its Top Dead Center. On open flywheel tractors you would be able to see the Left Hand Impulse mark at 3 o clock when that occurs, but on covered flywheels look for a dot/mark in the flywheels inner center hub to be at 6 o clock (flywheel cover center removed)
Once you get the Left Hand Cylinder (Flywheel side) at TDC on its compresion power stroke, simply install it so the rotor tip is lined up with and pointing to where the cap tower that leads to the left cylinders plug would be located and the cam is opening the points, SIMPLE AS THAT Hopefully lol.
The coil fires when the points break open and at that time you need the rotor tip lined up with a cap tower so it can deliver the spark to the plug at that time.
Good Luck n God Bless
John T
Clooney
09-08-2004 04:12:42
Bill, I don't a Wico XB handy where I'm at now but by looking at one it shouldn't be too hard to figure out..
You can do it the way you suggested but that is WAY more work than needed.. All you really have to do is remove the L/H spark plug,, then pop the center cover out of the flywheel cover,, then rotate the engine in the starting direction [either with the starter, or with slotted pipe in the center of the flywheel, or by placing in high gear & rolling the tractor],, once you feel compression on the L/H cylinder [flywheel side] just turn the engine until the flywheel slot is parallel with the ground [running fore/aft] ,, then install the distributor cam with the rotor pointing towards the L/H cylinder plug wire tower.. As easy as that!!!
Or just install it either way & try it.. You have a 50/50 chance of getting it right then see if your L/H spark plug sparks as you feel compression on the L/H plug hole while cranking the engine with the ign switch turned on.. If it doesn�t spark at the correct time either swap the plug wires tower to tower or reverse the distributor cam..
[email protected]
