1929 D, clutch fork, putting it back together
Bruce Klawiter
09-07-2004 20:28:49
Hello,
1929 D # 75049
I noticed in the parts book it includes a spring for the clutch fork shaft? Where does this go?
I would assume it goes in the bottom pocket of the clutch fork bearing. What prevents me from pulling the cluck fork shaft out of the bearing once it�s on the tractor?
Also on the clutch friction facing the staples have come out the hold the ends together, can I still use them that way?
Your help is much appreciated.
Bruce
Clooney
09-08-2004 03:38:27
 Re: 1929 D, clutch fork, putting it back together in reply to Bruce Klawiter, 09-07-2004 20:28:49
Bruce, you ask...
Quote: "I noticed in the parts book it includes a spring for the clutch fork shaft? Where does this go?
--It goes under the fork to kind of hold it up & center it while in use [takes the load off the fork ears as it rides on the clutch collar]..
Quote: �What prevents me from pulling the cluck fork shaft out of the bearing once it�s on the tractor?�
--There is usually either a �C� ring [sort of snap ring] under the clutch fork that snaps around the fork shaft, or a pin ended bolt that rides in the clutch shaft in a groove.. It�s been a while since I have been into a 29 �D� but I believe it�s a �C� ring but don�t make any money bets on that.. If there is a groove just below the bottom of where the fork sits on the splined fork shaft it would probably take a �C� ring..
Quote: �Also on the clutch friction facing the staples have come out the hold the ends together, can I still use them that way?�
--I�m not sure what your asking here but if the clutch linings are loose on the disks I have used JB weld to re-attach clutch linings on a few light duty use Deere�s after cleaning both the linings & plates with brake clean.. Not sure of the long term durability but it has held long enough until replacement clutch plates were obtained..
[email protected]
