435D or a 30-06 Deutz
Sponz
09-07-2004 19:59:41
I know most of you arent real familiar with the Deutz 30-06 but ive been around one and its one of the most reliable tractors around. Very simple in design and doesnt burn much fuel at all. It has plenty of low end torque. Now i havent been around the 435 but im more of a John deere fan. From the little i know about the two i think they are about the size i need.Just curious to the Pro"s and Con"s of both. Any thoughts app. thanks
buickanddeere
09-08-2004 06:08:14
 Re: 435D or a 30-06 Deutz in reply to Sponz , 09-07-2004 19:59:41
The 435 is ok as long as the engine has been rebuilt to the later "N" specs with N35 injectors and has the upgraded blower seals/valve springs. Don't add any ballast and using clean fresh trans oil the ring and pinion is fine. If horsed around when stuck or overballasted and lugged in low gear the R&P will wear out. Easily checked by looking through the top PTO cover. If the R&P goes then install the much beefier slower speed R&P from JD 1010 prior to serial number 31,000. The HP is only about 35HP at pto speed of 1850 but 2400rpm/40HP is allowable with new valve springs and follower springs. And weighing about 4000lb it's a utility rather than a field tractor. Category I three point hitch for use with smaller equipment. The 435 will certainly hold its value compared to the Deutz. The 435 should also use the later muffler sold at JD. Even so your neighbors will know when you are out tractor driving and wonder what is going on.
