Dust excluders
Soldier Tom
09-07-2004 19:02:18
How do you attach the dust excluders to a 720 D'sel NF? Must they be welded? One of mine is missing, the other one is welded on. The ones I got from Deere look like they would attach without welding. I know the hubs come off, then the excluders go on, will they stay in place without welding? The service manual didn't get into it. Thanks in advance.
~Walk in peace~
Soldier Tom
Mike M
09-08-2004 09:45:01
 Re: Dust excluders in reply to Soldier Tom, 09-07-2004 19:02:18
What you discribe sounds more like the felt retainers that go into the hub which you can still get. Those pieces welded to the spindles were NLA last time I checked.
Clooney
09-08-2004 03:23:15
Soldier Tom, I can't speak for the Deere replacement parts as I always just remove those dust excluders from an old used front end.. The originals & ones I put on must be welded on to hold in place.. If the ones you have just push on I would be worried about them rotating or falling loose when in use if not at least tac welded..
[email protected]
Soldier Tom
09-08-2004 17:36:48
 Re: Dust excluders in reply to Clooney, 09-08-2004 03:23:15
Thanks, looks like welding it is. I was afraid of that. Yea, it wasn't the felt, the metal dust excluders are what I was talking about. They really get banged up pretty thouroughly don't they? One is totally gone the other one is a bent up.
Thanks again,
~Walk in peace~
Soldier Tom
Clooney
09-09-2004 03:38:04
 Re: Dust excluders in reply to Soldier Tom, 09-08-2004 17:36:48
Soldier Tom, while I haven't ever done it myself-- if you don't have access to a welder you might be able to drill a couple of small holes in the excluder & knuckle, then tap the holes & attach that excluder with small bolts or screws.. Just be sure the screws aren�t I in the hub run area..
Clooney
