730 D lights and clutch question..
jdjoe_indiana
09-07-2004 18:35:43
I have a row crop with factory deluxe fenders. I have the two forward facing lights on each fender. On the right fender I have a rear facing lamp, on the left fender I have a amber and red light. I have no light on the backrest with the indent for the lamp. I was at an auction on Saturday and saw a 730 with headlights on the rods coming from the instrument column similar to how A,B,G"S are mounted. Is this what I should have or only if the tractor had clamshells?
Next main concern is I have a heavy chink in the clutch at idle, I am assuming its the bearing the clutch idles on when un engaged. How hard is it to get this changed. How do you get the driver disk off? I have been into my 41" B"s clutch and changed bearing but am nervous on this one. Thanks Joe
TW
09-08-2004 04:33:27
 Re: 730 D lights and clutch question.. in reply to jdjoe_indiana, 09-07-2004 18:35:43
The flat top fenders were optional on the 730. I purchased a 730 gas without fenders about 10 years ago that did not have fenders and had the headlights as you described. I bought some used 730 fenders at a salvage yard and removed the other lights.
To be certain they are the correct fenders always look for the absence of a hand cutout on the right fender. The 530-730 fenders did not have the cut out on the clutch pully side of the tractor.
If the tractor has the cutout on the right side then they are fenders off a new generation tractor.
msb
09-07-2004 20:49:05
Sounds like you have a set of 4020 fenders on your tractor.
As far as your clutch noise goes, the first thing I would check is the crankshaft endplay on a 730 Diesel. They are kind of prone to loosening up.Remove the flywheel cover on the left side of the engine.Then set up a dial indicator on the outside of the flywheel ring gear teeth.Snap the clutch in .Read the measurement and then pull the clutch lever all the way to the rear. Check it a couple times.Read the indicator again.Can't remember,but I think it should be .0050--.007"---- A ball joint wear indicator works real good for this.
jdjoe_indiana
09-08-2004 05:38:35
 Re: 730 D lights and clutch question.. in reply to msb, 09-07-2004 20:49:05
My fenders to not have the handhold on the right fender so I confident they are original. However that dosn't mean someone put the amber/red lamp on later. Should that be there? Should I have a lamp on the back of the seat rest? I will have to check crank end play, will have to find someone with an indicator. Thanks Joe
