JD 2010 hydraulic problem-36A lift
Carolyn
09-07-2004 18:18:16
Okay my lovely JD 2010 is being finicky-it won't lift with a load but lifts just fine without. I've looked and looked but can not figure out how to bleed the hydraulics, can anyone help? I do have the original manual but it doesn't clearly explain how to bleed the system. Thanks
ki0au
09-07-2004 23:06:09
 Re: JD 2010 hydraulic problem-36A lift in reply to Carolyn, 09-07-2004 18:18:16
My first thought would be to clean the hydraulic oil filter. It is under the right foot rest, the round cover is held on by three bolts. You need to drain the hydraulic oil before removing the filter cover. Give the filter a good cleaning in solvent and then see what happens.
A dirty filter is one of the inherent problems of the 2010. You can search the archives for more on the problem. Usually the power steering will start to fail first. You may also be able to hear the hydraulic pump cavitating.
If air is the problem, I think you can bleed the system by operating it several times.
Good luck
-Andy
