2010 hydraulics - technical question
farmergreen
09-07-2004 10:58:22
Was moving tractor with cutter lifted. Hit a bump, heavy cutter went up too far. Rockshaft housing shattered, rockshaft arms went limp. Located a used housing with rockshaft included, that came with valve housing, but used valve housing had missing valves, and some valves with damaged springs. Replaced all valve o-rings on my original valve housing then attached to rockshaft housing with new gaskets. Can't figure out why hydraulic fluid is pouring out of the top of the valve housing coming from the center which is the cut-out oil reservoir on the top of the housing. It is not a leak. Once the engine is cranked, a waterfall of hydraulic fluid is pouring over the top of the valve housing into the tranmission case. The pump is okay and the fluid line to the rockshaft housing is okay. All rings, including the rubber rings around the rockshaft piston have been replaced for a tight seal. I have the 700 page detailed JD repair manual and I have done everything it has recommended.
farmergreen
09-08-2004 05:51:31
 Re: 2010 hydraulics - technical question in reply to farmergreen, 09-07-2004 10:58:22
Andy,
Thanks for the quick reply. The manual only showed a skematic of the "oil reservoir" but no mention of oil flowing out of it continually. I hope you are correct. With new seals and rings, the hydraulic valves ought to be factory new. Thanks again for the insight and heads up response.
ki0au
09-07-2004 18:41:06
I had the rockshaft apart on my 2010 last month tracking down some PTO glitches. I think the �waterfall� (aka oilfall) that you are describing is normal. When looking into the rockshaft with the plate under the seat removed, you will see a waterfall of oil. If you operate the rockshaft, when raising the lift the oilfall should slow down.
If the lift works and the rest of the hydraulics work then it is fine.
If the lift does not work, the only thing I can think of is not getting the hydraulic line reconnected to the rockshaft housing, it is the one held by two bolts inside the housing.
Good luck. The 2010�s are not all as bad as people make them out to be.
-Andy
