Gene, if youre supposed to be running 6 volts on the coil but are running 12, that doubles the coil and points current and subsequently puts more load on the condensor as it has to absorb part of the current rush when the points open and the coils primarys circuit is interrupted. Sorry, I have no 3010 wirign diagrams and dont even know if actually it uses an external ballast resistor (drops 12 volts to 6) and a 12 volt coil with a start by pass circuit or simply a full 12 volt coil????? ?? On your voltage measurements, they need to be taken with the ignition on AND THE POINTS CLOSED, otherwise there wont be much voltage drop acrosss any ballast (no current flow except for meter) and it will still read 12 volts EVEN IF IT HAD A GOOD BALLAST. If its a 12 volt coil (no external ballast) with the ignition on and points closed, the voltage should be near 12 on the coils high input (NOT to distributor) side and near ZERO on the coils other to distributor side. If its a 6 volt coil and you have an external ballast, it should read around 6 on the coils high side and again, ZERO on the to distributor side. If it uses a ballast and has a working start ballast by pass system (like an extra I terminal on a solenoid which is hot only when cranking) what it does is supply full unballasted battery voltage to the coil (by passes ballast) ONLY WHEN CRANKING for a hotter starting spark but then once running, the ballast is back in the circuit so the 6 volt coil just sees around 6 to 7 volts. Look n see if you have a 6 volt coil,,,,, a series external ballast resistor ahead of the coils input,,,,,and a working by pass system. You can take some coil voltage readings when setting with ign on and points closed, then see what it measures at cranking n running to figure some of this out. Enemies of condensors are excess coil n points current and heat, so some of the above checks may help isolate the cause. If you have a 6 volt coil and are running it at 12, that may be your problem. If it uses a starter solenoid with an extra I terminal (NOT the S solenoid activation terminal) make sure its HOT ONLY (via the battery cable) ONLY WHEN CRANKING. You can unhook the wire to the coil or ballast for measuring so youre not reading the ordinary voltage from the switch. See if it reads hot when cranking BUT THEN GOES BACK TO ZERO (if other wire to coil/ballast disconnected) when shes not cranking. If you have a ballast and a 6 volt coil but the by pass circuit is failed (or miswired) and supplies 12 to coil at all times, that will burn up points quicker and shorten conddensor life. Let us know, post back your findings and any questions, Good luck n God Bless John T
