Good Morning Chuck, I wouldnt worry too much about that 10 amp charge rate for a while. The charge rate depends a lot (rest on Gens output and VR and its internal resistance values and spring tension and air gap adjustments) on what shape and state of charge and condition of the battery, so how was it before??? Heres a few things to consider. NOTE: If the system and ammeter is wired correctly, the Ignition (around 4 amps) is on the LOAD side of the ammeter, therefore if the ammeter indicates its still pumping 10 amps INTO the battery (if wired correct ONLY the battery is on ammeters other side, no other loads like coil to draw current) that means the Gen is supplying approximately 14 amps total, 10 INTO the battery and 4 to the coil. (i.e. NOT just 6 into battery) 1) First inspect the battery for electrolyte above all the plates and that no cells exhibit a gray or milky color, if so a bad cell could cause her to draw current, you might check all the cells for a Specific Gravity also. 2) If you have a decent quality charger, give the battery a good slow charge and then see how long the ammeter remains at 10 amps, remember if the battery were at a low charge state before, at only 10 net charging amps (10 INTO battery 4 to coil), it will take a while to charge, especially if the battery is bad in which case she may continually draw that 10 amps. 3) Once the battery is known to be at a full charge (you might have it load tested and its Specific Gravity checked at a battery shop) if she still always remains at 10 amps, keep a close eye on the electrolyte level as if she overcharges or boils over or outgasses badly, you could have a VR problem. 4) You can check the Gens max charge rate by dead grounding the Field post and see if the rate stays the same or increases. If it stays the same, that says the VR already is running at max charge rate (max field current) and is internally grounding the Field already. HOWEVER If the VR is correct for the Gen and ground etc., once the battery becomes charged, its supposed to switch some resistance (via a field current control relay) into that field ground circuit to reduce the charge rate !!!!! !! IF THAT RELAY IS BAD OR STUCK OR MIS ADJUSTED OR THE VR ISNT CORRECT, it may be stuck on constant HIGH CHARGE (dead grounded Field, no internal VR resistor added) which could potentially over charge or boil over or badly outgas at the battery and even harm it !!!!! !!!!! !!! SUMMARY Insure the Battery is good (maybe load tested and Specific Gravity checked at a shop), fully charged, no low electrolyte and no gray or milky cells,,,,, ,,,,, ,Insure shes wired correct BAT on VR to LOAD (NOT to battery) side of ammeter. The BAT ammeter side should have but one wire, to starter or battery etc. The other LOAD side of ammeter wires down to BAT on VR and powers the BAT input terminal on the switch if its a 3 wire VR system (BAT ARM FIELD). If its a 4 wire VR (BAT FIELD LOAD ARM) system, the switch gets its power off the VR's LOAD terminal instead of the ammeter. REGARDLESS, but one hot wire on Battery side of ammeter with loads on other side like down to BAT on VR and maybe switch (if a 3 wire VR). ARM (or GEN) on VR to Armature post on Gen FIELD on VR to Gens Field post. LOAD (only if a 4 wire VR) to switch. ,,,,, ,,,if a full charged good battery continues to draw 10 amps, do the test above to see if the VR is at MAX charge rate (VR may be bad like a stuck or bad or misadjusted field current control relay if it dont kick to low charge ever),,,,, ,,,and keep an eye on the battery levels until you can have the VR looked at. Post back any questions Good Luck n God Bless yall John T
