4020 hyd. pump
TedK/MN
09-07-2004 08:04:02
Noticed a few drips of oil under the hydraulic pump on my 4020 Standard, '65 model. Service manual tells how to go about R&R, oil seal should be pretty easy to put in. Any other things I should be looking for while I am at it? Everything connected with the hydraulics works fine, just this messy dripping. Hope this is going to be just a weekend project....Ted
Steph MN
09-07-2004 20:41:53
 Re: 4020 hyd. pump in reply to TedK/MN, 09-07-2004 08:04:02
Early to mid 60's pumps had this problem where oil would seep out between the seals on shaft, later pumps had small relief hole drilled between the outer seal and inner packing, a small (1/8"-1/4") line ran the oil from relief port to back of tractor and deposited into tranny housing
msb
09-07-2004 20:35:34
It takes a special "step" seal driver to install that seal.Otherwise it is very easy to drive the seal in too deep and block off the weep hole.You know that "drain' John Deere came up with when they couldn't keep those seals from leaking.Before you go to the troube of pulling the pump, try checking that little plastic "drain" line to see that is isn't restricted or collapsed.
Joe 123
09-07-2004 17:04:30
Need to completly tear down pump to install oil seal. Also blow air through the return line to make sure it is not plugged
thurlow
09-07-2004 09:42:14
I would check for leaks in the lines/fittings first; bunch of places for oil to 'dribble' from.....
